CB7Tuner Forums (http://www.cb7tuner.com/vbb/index.php)
-   Forced Induction (http://www.cb7tuner.com/vbb/forumdisplay.php?f=62)
-   -   a good affordable wastegate (http://www.cb7tuner.com/vbb/showthread.php?t=189757)
brand0n327 04-26-2012 06:06 PM
the turbo manifold i have is a log style with the waste gate mount on top..which wastegates can i use that will clear the hood..and wont break the bank? thanks
92smokeaccord 04-26-2012 07:36 PM
how cheap we talkin?like $100 or less.if so ebay has emusa wastegates.its a knock off company but its a good knock off company like megan.they probably last you a few years.
Joey GT-R 04-26-2012 08:12 PM
I wouldn't even do that. Most quality wastegates start at $300. Hell, even OBX's wastegate weighs in at $200. If you can't afford that, I would suggest looking into a used one.
brand0n327 04-26-2012 09:02 PM
right. i know the emusa ones are good a few of my friends have them.but the issue being is it being too tall..i might buy from them..luckily they are 10 miles away from me.
thepowderblue 03-17-2019 09:52 AM
Bump for emusa , wish I would have known that before I bought my 1st ebay wastegate. Am running an 38mm a emusa and it works well
Raf99 03-17-2019 07:26 PM
Don't cheap out on turbo parts. You're asking for trouble.
thepowderblue 03-17-2019 08:45 PM
It depends ... Some things are hit or miss. I wont go cheap with injectors again .
The emusa wastegate holds very consistent boost.
I had my tuner add boost cut just to be safe.
If buying cheap parts gets somone on the road boosted I say go for it as long as the parts work. I got a half way deacent turbo for my civic and the rest was cheap.
I had issues with eBay injectors so I had to buy python 550s.i also has issues with the cheap $45 wastegate right off the bat but I get a $60 emusa and its been working fine.
