CB7Tuner Forums (http://www.cb7tuner.com/vbb/index.php)
-   Audio/Electronic DIYs (http://www.cb7tuner.com/vbb/forumdisplay.php?f=168)
-   -   EXT: Soldering Wire (http://www.cb7tuner.com/vbb/showthread.php?t=210820)
dreamability 03-04-2019 07:20 PM
EXT: Soldering Wire
I'm making this DIY as an extension to my wire tuck DIY.
http://www.cb7tuner.com/vbb/showthread.php?t=210829
My wire tuck included extending wires.
I think it made it a lot cleaner and more organized to extend the wires rather than trying to make wires reach that are too short or that just barely reach.
I soldered and heat shrinked all wires that I had to extend. This just provides a better mechanical connection with no worry of future electrical failure.
You will need:
1) At least a 100 Watt Soldering Gun
2) 0.8mm 60-40 Rosin Core Solder and Flux
3) 500 grit sandpaper
4) A clean sponge
5) Wire
First take your clean sponge and get it moist.
Next get your solder tip and sand it down till its shinny metal then wipe it clean.
With your shinny clean tip in the gun heat it up and with a length of solder wire begin to melt and build a ball of solder on to the tip.
After the ball of solder sits on the tip for a few seconds gently knock off the excess solder and wipe the tip onto your clean sponge.
You should now see that the tip has a thin layer of solder over the metal and looks like this.
https://i.imgur.com/rGpdpRa.jpg
This ensures that the tip will be free from any impurities.
Benefits: The tip will get hotter, transfer heat better, not stick to the solder and just over all preform better.
You must wipe the tip on the clean sponge before and after each use to keep that layer of solder on the tip clean.
If your using a trigger type gun don't release the trigger until after you have wiped the tip on your clean sponge so as to wipe while still hot.
https://i.imgur.com/V6dVsIA.jpg
Next, the way I will show to connect the two ends of wire will ensure a solid mechanical connection.
So even if the solder was to crack your wires will still have a good connection
After you have your two ends of wire stripped slide a piece of heat shrink about 6 inches down one of the wires.
Don't let it be to close while your soldering or it will shrink in place
Now make two hooks with each end
https://i.imgur.com/Ceg0Nu8.jpg
Hook the two ends together like this
https://i.imgur.com/4SXTm92.jpg
While holding one hook securely twist the other hook back around itself.
https://i.imgur.com/GGfHcgD.jpg
Now do the same with the other end.
When finished it should look like this.
https://i.imgur.com/YZ8Cz8k.jpg
Coat the exposed wire that you just twisted with flux
Now your ready to solder.
Heat the solder gun up till at temperature, (about 10-20 seconds), and wipe it on the clean sponge.
Hold the tip to the wire along with the solder. Hold them both against the wire for about 10 seconds. The solder should begin to melt.
If the solder does not melt easily you may need to drag the tip across the solder to get it to start to melt.
Spread it across the wire with the tip.
Once the solder is spread wipe the tip clean.
https://i.imgur.com/vG1GLNl.jpg
Turn the wire over and repeat the process so the wire is coated all around.
Now slide your heat shrink down into place and heat with flame or heat gun.
https://i.imgur.com/zfBQeb6.jpg
That's it. If you have any questions or suggestions let me know.
G. Wiffington 03-20-2019 01:27 PM
Great DIY. Simple & easy to follow even for other projects besides automotive.
I like how you showed the way to properly twist the wires.
dreamability 03-21-2019 10:25 PM
Thanks, I really appreciate it! Glad I could do it and hope it helps.
Yeah how to twist the wires I learned from my father, "always make sure you have a good mechanical connection". Lol.
