CB7Tuner Forums (http://www.cb7tuner.com/vbb/index.php)
-   Technical (http://www.cb7tuner.com/vbb/forumdisplay.php?f=74)
-   -   How Do You De-pin a Thermostat Temperature Sensor Connector? (http://www.cb7tuner.com/vbb/showthread.php?t=211319)
fleetw00d 08-10-2019 11:29 PM
I was putting the engine back together after dealing with a broken timing belt and the electrical connector for the temperature sensor on the thermostat housing disintegrated when I tried to install it. It broke into so many pieces I can't figure out how to de-pin one from a spare harness I have. Looks like it is identical to the connector for the sensor on the upper hose connection to the head, so I have two chances.
https://live.staticflickr.com/65535/...3dc14d5c_z.jpg20190810_181842 by Paul Kemme, on Flickr
sonikaccord 08-10-2019 11:50 PM
Pull the white retaining clip thing out, then use a small pick or screw driver to press the clip holding the pin in.
You may have to Google some pin removal videos. They're all the same.
fleetw00d 08-11-2019 01:09 AM
The portion of the white part that survived the devastation looked like it was barbed or would snap over some internal feature, but I couldn't tell looking at the intact connector how I would release it - you think if I can get a small needle nose on it that it will just pull out? I can try it later today - like I said, I have two chances. If I finally figure it out, I can collect some at the JY.
Jarrett 08-11-2019 08:37 AM
You might have better luck with a hooked pick.
fleetw00d 08-11-2019 10:21 AM
That would assume I have a hooked pick. Another opportunity to buy a tool!
Jarrett 08-11-2019 02:18 PM
One place where the trinket selection at the Harbor Freight checkout counter comes in handy.
fleetw00d 08-11-2019 10:36 PM
Ace is the place. Picked up (no pun intended) a couple double ended picks this afternoon. One end of one of them broke almost immediately. I was able to pull the white piece out of one connector which made it more obvious how to release the sockets. I was able to repair the connector for the sensor on the thermostat housing. Double checked the one on the head discharge; the latch on that one had failed. I also noticed that one of the wires was broken. I hate to cut the spare harness to solder the connector assembly to my harness - are the pin/sockets available separately to put on my harness wires and just swap the plastic connector housing?
With the white ring pulled out:
https://live.staticflickr.com/65535/...3b2c42b492.jpg20190811_161214 by Paul Kemme, on Flickr
Bend the green tabs to the side to release the sockets (worked easily on one, still couldn't get the second set to release):
https://live.staticflickr.com/65535/...821e1573c0.jpg20190811_154117 by Paul Kemme, on Flickr
Found a source for the connector: https://racespeconline.com/collectio...da-connector-3
Aug. 14, 2019: Ordered three. One to fix Ruby, one to repair the harness I took one from, and a spare. They are gray instead of green.
https://live.staticflickr.com/65535/...04b8963343.jpg20190817_185206 by Paul Kemme, on Flickr
