CB7Tuner Forums (http://www.cb7tuner.com/vbb/index.php)
-   Members' Rides (http://www.cb7tuner.com/vbb/forumdisplay.php?f=42)
-   -   Dark_Accord : 1991 Accord EX (http://www.cb7tuner.com/vbb/showthread.php?t=141693)
Dark_Accord 08-17-2009 12:08 AM
Me and my step dad share and work on this car, its my familys Daily driver and has been a good car over the years
Most Recent Pic
needs a bath
http://i66.photobucket.com/albums/h2...t/IMG_0764.jpg
Favorite Pics
http://i34.tinypic.com/2j3ogo3.jpg
and theses
http://www.cb7tuner.com/vbb/showpost...&postcount=656
Engine Specifications:
F22A4 with 180 compression across the board 340k miles.
Engine Misc.:
NGK plug wires
NGK Vpower
Short Ram intake
F22a6 Intake manifold
Blocked off EGR, FITV, IACV, Air boost
Exhaust:
F22a4 Header VHT High temp painted flat black with shiny new nuts
3" cat back dual Magnaflow Resonators
Fart Can (lol)
Drivetrain:
Fidenza Flywheel
Exedy stage 1
Weight reduction & transfer:
Gutted trunk
Suspension, wheels & tires:
Eagle Alloy rims
Neuspeed Strut Bar-Sold
Good year tires
Newer Struts
94 EX rear sub frame
94 EX rear disks
94 EX rear sway bar
Rebuilt Front suspension
Interior:
brown interior
Woodgrain sticker crap (removed)
G1 legend shift knob
Glow shift gauges:
AFR, VOLT, VAC
ICE:
Deck- JVC with thumb drive reader
Rear Speakers- JVC 6"
Front Speakers- Pioneer 6"
Exterior:
Clear corners ( Removed)
Amber Corners (broken)
Old tint-Removing
EX Lip
Custom Blackhoused bumper lights-removed
Black trim with bronze flake
Removed EX badge from trunk
Luminics Ultra white low beams
Relocated Plate using CD5 bracket
OEM Moon Roof Visor(removed)
88 Legend moon roof visor
OEM Spolier-Removed
Black Door handles
Black Mirrors
Antenna
92-93 Sedan trunk, bumper grille Conversion
Oem corners
94-95 Accord bumper lights
5% tint on rear side windows, rear window coming soon
Coming Soon:
Repaint trim again
Repaint door handles
install CD5 rear corners
Fix CD5 side skirts
replace fender
90-91 grille
blackhouse headlights
lower
larger sway bars
new tires
much more
What I've Fixed/Replaced:
Hooked amp back up-Removed again
Replaced Hub
New front speakers
Cleaned up interior
Removed Woodgrain sticker crap
(valve job,Timing belt Water Pump all other belts , Random seals and gaskets , Axles and other shit were just recently replaced by previous owner)
Replaced VSS 5 times
Smogged
PCV Valve
Cleaned inside out
Cleaned IACV
New NGK V Power Plugs
New Radiator
NGK plug wires
New Grounds
New headlights
New corner lights
Fixed Air con
Removed Power Steering
Bought neuspeed sturt bar
New Muffler
New Alternator
New Lower radiator hose
New FR UCA
New brake master cylinder
New Starter
2 New Tires
New heater/fan knobs
New Fuel filter
New plugs again
Removing Tint
New Antenna
Installed Catch can
Replaced Rusty engine bay bolts with shiny gold ones
new tires Barum Bravuris 2
Replaced Radiator again (new one blew out after 10 months)
Replaced more cooling hose
Replaced catch can hose
Replaced VSS again
Replaced Glove box latch
Replaced interior door handle
Replaced cig lighter
Replaced broken fuel door
Replaced Interior door handle again
Installed mazda cd player
Installed 2 more steelies so it matchs
Replaced front brake pads
Replaced Plugs again
Replaced mazda cd player with pioneer
Replaced infinity refrence with walmart speakers
Swaped the DIY grille on to my car and stock 92-93 on this car
92-93 Conversion
Replaced alternator again
Reinstalled Cruise Control
REinstalled Power Steering
Toped off Freon
Rear Disk conversion
Iradium plugs
NEw rims
Exedy stage 1 clutch
Fidenza light weight flywheel
Replaced Left UCA (right was replaced less then 2 years ago)
Replaced both lower ball joints
Replaced Tie rods
Replaced LCAs
Replaced Clutch master cylinder
Replaced Clutch Slave Cylinder
Welded on fart can
Replaced Rear brake pads
Replaced caliper pins
Replaced Right Axle
Replaced Deck with new JVC with thumb driver reader
Replaced rear speakers with JVC
Replaced Valve cover gasket
Removed PS
Replaced oil pan and gasket
painted header and new gold nuts
More items i cant think of...
Frist Photoshoot
http://i66.photobucket.com/albums/h2...ot006Large.jpg
http://i66.photobucket.com/albums/h2...ot009Large.jpg
Repainted trim
http://i66.photobucket.com/albums/h2...m013Medium.jpg
Amber Corners
http://i66.photobucket.com/albums/h2.../corner002.jpg
NGK wireset and new rad + tune up
http://i66.photobucket.com/albums/h2...oshootz017.jpg
Photoshoot 2
http://i66.photobucket.com/albums/h2...oshootz008.jpg
http://i66.photobucket.com/albums/h2...oshootz011.jpg
Orange Valve cover
http://i35.tinypic.com/121wpyw.jpg
Luminics Ultra white H4 bulbs
http://i38.tinypic.com/ohlj40.jpg
Accord Badge and black "H"
http://i36.tinypic.com/1fvmsx.jpg
Neuspeed bar and Power Steering removed
http://i37.tinypic.com/15n99mv.jpg
Tsudo Muffler
http://i34.tinypic.com/30wse91.jpg
day 1
http://i242.photobucket.com/albums/f...b7004Large.jpg
more old pics
http://i242.photobucket.com/albums/f...b7006Large.jpg
http://i242.photobucket.com/albums/f...b7008Large.jpg
http://i242.photobucket.com/albums/f...b7009Large.jpg
http://i242.photobucket.com/albums/f...b7010Large.jpg
http://i242.photobucket.com/albums/f...b7011Large.jpg
http://i242.photobucket.com/albums/f...b7012Large.jpg
http://i242.photobucket.com/albums/f...b7013Large.jpg
http://i242.photobucket.com/albums/f...b7017Large.jpg
http://i242.photobucket.com/albums/f...b7019Large.jpg
http://i242.photobucket.com/albums/f...b7020Large.jpg
http://i242.photobucket.com/albums/f...b7025Large.jpg
http://i242.photobucket.com/albums/f...b7026Large.jpg
http://i242.photobucket.com/albums/f...b7028Large.jpg
Dark_Accord 08-17-2009 12:09 AM
Cleaned up interior and removed wood grain and installed a G1 Acura legned shift knob
http://i242.photobucket.com/albums/f...ng003Large.jpg
http://i242.photobucket.com/albums/f...ng004Large.jpg
http://i242.photobucket.com/albums/f...ng005Large.jpg
http://i242.photobucket.com/albums/f...ng006Large.jpg
http://i242.photobucket.com/albums/f...ng007Large.jpg
http://i242.photobucket.com/albums/f...ng008Large.jpg
http://i242.photobucket.com/albums/f...ng009Large.jpg
http://i242.photobucket.com/albums/f...ng010Large.jpg
http://i242.photobucket.com/albums/f...ng011Large.jpg
http://i242.photobucket.com/albums/f...ng012Large.jpg
http://i242.photobucket.com/albums/f...ng013Large.jpg
http://i242.photobucket.com/albums/f...ng014Large.jpg
http://i242.photobucket.com/albums/f...ng015Large.jpg
Dark_Accord 08-17-2009 12:51 AM
http://www.youtube.com/watch?v=T5VCM...er_profilepage
19TcappaLX 08-17-2009 03:52 AM
is that another Cappuccino brown cb i see.very nice for $300.5speed EX.thats a great deal.good luck with it on your plan.
jhondayaaj 08-17-2009 12:22 PM
good start man. keep it up.
kouzie 08-17-2009 02:10 PM
Its about time I see you with a CB:thumbsup::thumbsup:
What's the plan for it?
:bouncy:
lilb_1979 08-17-2009 02:34 PM
A cappuccino EX coupe! Very nice!
Car looks great, just some TLC and your good.
I still cant believe you picked it up for $300! Your one lucky guy!
Dark_Accord 08-17-2009 09:43 PM
why yes it is a cappuccino brown cb :bouncy:
Thanks
:bouncy:
hell yeah it is! :bouncy::bouncy: so far plan is to get it up to par ( with the civic cant be rolling around in an accord thats more beat up then a civic haha)
then from there who knows :bouncy:
cappuccino ftmfw and yeah im still shocked on the price! funny thing is when i offered $300 she jumped at the price.. i probably could of asked $250 and she woulda said yes :lol:
today i took my hub in to get new bearing pressed in they said the hub was fucked went to junkyard grabbed a whole spindle for $75 it has some bearing play so that will need to get it replaced in near future (cl brake conversion maybe?) but it didnt seem to make any noise when moving the car around the driveway.. insureince company is closed so i cant test drive it until tomorrow
right now im off to go replace the the dimmer light switch i got one from the junkyard since the faceplate is missing on mine so the lightbulb just shines right at yours eyes :lol:
oh and i need to drain some oil out becuase someone thought a 4 cylinder accord took 7 qts of oil :bash::banghead:
Night Wolf 08-17-2009 10:13 PM
nice brown interior
Dark_Accord 08-17-2009 10:16 PM
Originally Posted by Night Wolf (Post 2173410)
nice brown interior
gotta love it!
anywho just took it for a drive around the block.. it threw a cel im thinking tis the VSS since the speedo and odometer dont work.. ill check the codes later on tho
Night Wolf 08-17-2009 10:18 PM
wheres the 4th alloy
Dark_Accord 08-17-2009 10:58 PM
it has the cholo style rims in the back and steelies up front lol...
93tunerofdacb7 08-17-2009 11:15 PM
nice ide like to get my hands ona coupe.. and a cappucino coupe at that
Dark_Accord 08-18-2009 02:41 AM
keep looking and your find a clean one soon enough :D
tonight i cleaned the engine up some no pics tho lol also put a new pcv valve in added brake fulid swaped the tires around (cholo rims on bad side steelies on good side worn to wire tire on back now the car no longer pulls )
and drove it around some it drives good except for the cel from a bad vss
Dark_Accord 08-18-2009 03:56 PM
damnit drove all the way out to bakersfelid got the last vss in the junkyard (after walking down every damn row!) poped it in still throws a cel and still doesent work ! :( gotta get it fixed asap so i can smog it as i know it wont pass smog if the cel is on
Dark_Accord 08-18-2009 11:25 PM
got a vss from honda only down in sun valley for $50 also got a radiator drain plug
works now.. but the bolt hole doesent line up with the hole in the trans :S
Dark_Accord 08-19-2009 03:57 PM
she passed smog today.. got the rego for it, at 1.30 going to get insureince for it then go wash it at the car wash woot
lilb_1979 08-19-2009 04:30 PM
Waiting for pics!! :bouncy:
Oh I'm rocking a baby seat too! lol Well a booster seat.
kouzie 08-19-2009 05:24 PM
I can't wait to see what you got in store...:bouncy::bouncy:
vietkid_2006 08-19-2009 05:29 PM
nice cheap pick up :tu:
