CB7Tuner Forums (http://www.cb7tuner.com/vbb/index.php)
-   Forced Induction (http://www.cb7tuner.com/vbb/forumdisplay.php?f=62)
-   -   AEM electronic boost controller location (http://www.cb7tuner.com/vbb/showthread.php?t=210377)
Raf99 07-04-2018 06:59 PM
In the generic setup for AEM boost controller (EBC) it looks something like this. Obviously I'm using the 2nd method with the T and the external waste gate. My question is, does it matter where I put the T split?
more specifically......
- Can I put the EBC near the WG with two 6" lines, and a long line back to the intake manifold?
- OR have the electronic boost controller up near the firewall with with two lines running to the EBC
I can't find an answer for this; does the distance matter or can I put the EBC anywhere I choose? (ie - EBC & Lines in the fender)
https://www.ampefi.com/wp-content/up...C-solenoid.png
Grumpys93 07-04-2018 07:25 PM
I would believe that because this is a sealed system (sort of speak), Pascal’s law should apply which is force is exerted the same in all directions. Unless I am just trying to sound smart and I’m dumb. But I do not believe distance changes anything, but having the air flow through the intercooler and other restrictors would. If it did make a difference it would be very minimal.
Raf99 07-05-2018 04:25 AM
Originally Posted by Grumpys93 (Post 3284106)
I would believe that because this is a sealed system (sort of speak), Pascalís law should apply which is force is exerted the same in all directions. Unless I am just trying to sound smart and Iím dumb. But I do not believe distance changes anything, but having the air flow through the intercooler and other restrictors would. If it did make a difference it would be very minimal.
Yep, that's what I was thinking. Whether it was 3' or 15' of hose/tubing the PSI will be the same.
Jarrett 07-05-2018 09:07 AM
My harness is being made to fit mine up under my dash. My harness builder is fairly well versed in boosted performance applications and didn't seem to mind. All to say that mine will be a remote location with plenty hose length to contend with.
I wish I could offer you something more scientific than that, but I'm not really to that stage yet.
Raf99 07-05-2018 04:10 PM
I asked my tuner and he said the shorter the hose the better. Because you want to maintain pressure and have precise on/off points. But for all I know there is a setting in S300 for WG lag to address the delay in the EBC reading the manifold pressure vs. the BOV pressure.
But at the same time I can see using 100' of hose being an issue. But for the distances I would use (no matter what route I take) it's negligible.
turbo90accord 09-11-2018 04:40 PM
Shorter distance allows for faster boost response. It takes a lot longer to vent 25psi from a 10 foot hose than a 1 foot hose.
Raf99 09-12-2018 08:01 AM
Shorter to the WG I'm assuming.
