CB7Tuner Forums (http://www.cb7tuner.com/vbb/index.php)
-   Beginner Appearance (http://www.cb7tuner.com/vbb/forumdisplay.php?f=108)
-   -   Wheel setup (http://www.cb7tuner.com/vbb/showthread.php?t=210072)
Renz0 02-10-2018 04:54 AM
Wheel setup
Hey, I'm buying myself a set of nice wheels.
The question is, it CANNOT pass the fender, but I don't want to stay on 15's like now, it's stock.
Can anyone give me a good advice on wheel width, diameter and so on? I don't want to roll my fender just yet. 16x8 ET0 sticks out too much.
Bunta 02-10-2018 08:13 AM
A good way to really get an idea is to look at pictures on here of other members rides with aftermarket wheels (especially their build threads) and see how theirs look, not necessarily wheel style but strictly how they sit within the wheel well and see if they mention their wheel specs. This will also give you an idea how different tire sizes will look on similar spec wheels.
I think regardless of offset, an 8" wide wheel is too much for our chassis without rolled/pulled fenders. Stock size is like 15X5.5 so you could make a small adjustment to this and look for something along the lines of a 16X7.
sonikaccord 02-10-2018 02:48 PM
Offset and width will determine how much your wheel sticks out. Diameter is pretty subjective. You may like how 20's look, but prefer how 17's perform.
Like Bunta said, you'll have to find someone with a similar setup.
Raf99 02-10-2018 08:14 PM
Love my sig :)
Renz0 02-11-2018 03:06 AM
I want to go with 16x7, with low offset. Idk if 0 or 15.
Anyone running that,or?
Bunta 02-11-2018 08:34 AM
The lower the offset the more the wheel will "poke". You will only be able to go so low of an offset with a 16X7 until your wheels start to pass the fender. Also depending on which size tire you go with they may be wider at the sidewall than the wheel. If you want more offset and still stay within your fenders you'll have to go to a skinnier wheel like a 16X6 (if those are even made)
Your thread got me curious what specs sit flush or nearly so with the car body. Look up member 92smokeaccord, his signature picture is probably what you are looking for (as am I) and he told me his specs were 16X7 with an ET of +25.
Raf99's signature is also a good example.
ridin_low07 03-17-2018 02:07 AM
I have been looking into 16x8s or 17x8s. But like they said above me offset is going to be key to determining the look and fit that you are shooting for.
