Manual Swap question
This topic is closed.
    Do you have to relocate the transmission mount when swapping from auto to manual?
    http://www.cb7tuner.com/vbb/showthre...=&threadid=588 hope it helps...i didnt really read through it all but i think its got everything
    Burrito Bandidos: It will change your fuckin life
      i think you do
        popular topic of discussion:
        OEM way of doing it is cut the old mount bracket off the side of the engine bay and weld the new bracket in its place. you can then use a manual transmission and a manual tranny mount and itll fit like stock.
        another option thats been brought up is to use a 4th gen prelude (92-96) or 5th gen accord (94-97) manual transmission mount bolted onto the new manual transmission, and that will compensate almost enough to make it so you dont need to weld the new bracket on the side, you can leave the original one there. its not 100% perfect, so youll need to add 3/8" or maybe 1/2" spacers on the driver side mount to hold that side a bit lower. the thing abotu this is that it saves you from welding the new mount, but it requires either a 5th gen accord or 4th gen prelude transmission to be used, since either of those mounts wont bolt onto a stock CB7 manual transmission. so this method works for people going from auto F22 to manual H22/H23/F22B...
        heres a couple threads on it:
        http://www.cb7tuner.com/vbb/showthre...ht=auto+manual
        http://www.cb7tuner.com/vbb/showthread.php?t=37788
        as you can see (most clearly from the third link i posted) this topic has been covered dozens of times, so next time please try running a search before you post up a new thread! the search button is towards the right side of the blue bar at the top of the forum.
