92-93 bumper on a 90 (conversion)
    If i swap the bumper off a 92-93, install JDM one-piece and the matching grill am i going to run into any fitmant problems?
    My Ride
    myspace
    as long as the grill and the headlights are from a 92-93, then no
      might need to either shave the 90 bumper support bar, or install the bumper support bar from a 92-93:
      http://www.cb7tuner.com/vbb/showthre...ghlight=bumper
      headlights and grill should be fine.
        thanks guys thats all i needed to know oh yeah if anyone knows were i can get a G square grill let me know
        My Ride
        myspace
          yea i found out the hard way.. when i tried to install the 92 93 on a 90 91 front bumper support.. the 90 91 is bumper support somewhat fatter and the 92 93.. so i had to go buy one..but if you put it side by side.. they look the same..
            thast weird i didnt have anyproblems putting mine on, i used the 91 grille 93 bumper, 93 jdm headlights,, not fitment probs at all,, ill post some pics
            -95 JDM H22 LSD-
            -HYTECH Header-
            -Skunk2 IM-
              please do also i was told that you can switch the thin 92-93 trim onto a 90-91 will that still look like it was meant to be there or is the indent in the door bigger also
              My Ride
              myspace
                me and dustin had no problems putting the 92-93 bumper on the 90-91 support... should just go on the same... only problem you MIGHT run into is the 92-93 bumper has a lip on the top between the headlights, dont know if the 90-91 grill will fit over it or not?
                OS^e
                1993 Honda Accord LX Coupe
                My Members Ride's Thread
                StickyDilJoe: "JDM may be a fad, but making your car look like shit... thats forever"
                  hmm yea i found it weird that the 92-93 front bumper barely fit on a tight snug on the 92-93 FBS(front bumper support).. when i tried putting the 92-93 bumper on the 90-91 FBS it felt almost impossible.. so i called 2 junkyards and a dealer..they all said that the fbs for 90-91 vs 92-93 is different..
                    thats odd...i have a 90 and when i did my 92-93 bumper swap i didnt have the FBS fitment problem...who knows tho. i had 90-91 headlights till i scored jdm 92-93 one piece heads. i fixed the grille fotment problem by enlarging the holes where u screw the grille onto the lights and slid it out, thenit fit out over that lip rather than sit on top of it.
                    heres an older pic of it when it was first done with the grille slid forward just over the lip
                    In memory of Jameel Johnson 4.30.05--You will never be forgotten...
                    MY Car
                    HydroDunk Mixtapes...check it out
                      I know i had no problem putting my 92-93 bumper on my 91
                      N/A is best....
                        Do it. It will look ten times better. To bad youll still have those square moldings and auto belts though......
                        JDMED
                        buy my jdm part
                        http://www.cb7tuner.com/vbb/showthread.php?p=544951#post544951
                          hater hehe
                            Nothing that a day at the j-yard won't fix. Everything's interchangible if you know what you're doing.
                              the man speaks the truth.
