lowering car, which camber kit?
    so i am planning to lower my car within the next few weeks.
    i want to know how many degrees (approx.) my camber will change from a 2" drop.
    I want to know this so that i know which camber kit to get. i see some kits that adjust from -1.5 to +1.5 degrees, +1.5 to +3, and so on. I would just get the kit with the largest range, but those are more expensive.
    To sum up my question, what range camber kit would i need (if i even need one) for a drop of 2"?
    Im on neuspeed race and i had about 2.9* on the right and 3.1* on the left when i did my alignment yesterday. I had the ingalls anchor bolt style camber kit for 1.5* to 3* of correction, but i didnt like how it pushed the control outward and made it "bang" against the frame rail. This was resulting in bent UCAs. I would reccomend taking a look at the Ball-joint style camber kits.
      the race springs dropped you 2.2F and 2.0R correct?
        Yes sir.
        http://neuspeed.com/products/product...mport&p_id=882
          cool cool.
          do you know if the camber and toe can be set close to zero on a 2" drop?
            Toe can be set to zero with any drop, and yes the camber can be set to zero with the ingalls anchor bolt kit but you may have to do a little "beating" on the frame rail so that your control arms wont hit.
              cool. guess i'll look into getting the balljoint kit
                I'd be more worried on toe rather than camber.
                1996 Honda Civic LX 2009-2012
                2012 Kia Optima LX 2012-2013
                  ^ Yay I am not the only that knows this. Everybody is telling me that o my tires are going wear out so fast, But i set my toe at 0.
                    even if i set the toe, camber will still affect tire wear. anything that is -2.0 is going to wear fast
                      this is true ^ your tires will still wear with that kind of camber, most rookies dont know that lowering your car also affects the toe \\ //
                      like cakeboy says, that will make all the difference in your tire wear and handling as well. Im on a 2+in drop with no camber kit and Ive had the same tires (205/40 R17) on the front for a year now, im missing about an inch of tread on the insides, not bad for autozone specials for 65 a peice.
                        spc balljoint camberkits are nice... its what i have and i really like them... theres a spacer on top you can flip around to allow for more adjustment. i keep my spacer witht he short's adjustment so i still have a little camber and so the balljoints dont hit the inner fender...
                        Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
                        Originally posted by deevergote.
                        But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
                          I understand what you are saying. I know that it is going to affect the shoulder wear, versus the Scrubbing effect you would get with the toe being out. I really wore a set out back when i first lowered my coupe. I had no idea about alignments at the time.
                            Keep up on the rotations to make them last longer. (rears wear way slower even if there is -20 degrees of camber)
                            Gary A.K.A. Carter
                            [sig killed by photobucket]
