SUSP: Upper control arm replacement (pics!)
    Obviously, get your car up, both sides, and get the wheels out of the way. Jack stands in the correct places, not on the suspension!
    Remove the two bolts that hold the nut cover, and loosen the bolt. The joint popped on mine just from the force of the spring.
    Up top, remove the two nuts holding the upper arm to the body.
    Finish removing the nut on the ball joint, and wriggle that bad boy out of there.
    Yay for you.....it's out!
    New vs. old
    The upper mounts don't come tight, and unless you want to yank the shock out, you aren't going to be able to tighten easily while on the car. Do it now, not too tight! I couldn't move my originals by hand at all. Not so good for suspension compliance!
    Now, get'er back in!
    Tighten down the upper nuts, and fit the ball joint. Don't forget the cotter pin.
    A touch of the good stuff on those tiny bolts...
    ...and you're done.
    Ebay suspension bits, from Arm-Can
    2003 Maxima SE Titanium Edition
    Polished Titanium ext, heated black leather int, heated leather steering wheel, HIDs, 255bhp, 6 speed, 15% tint.
    1993 Suzuki GSX1100F 136bhp
    did u get an alignment after doing this?
      No need to, only thing adjustible on our cars is the toe which goes untouched if you don't mess with the tie rods.
      Good stuff though.
      Originally posted by lordoja
        word of caution. sometims the bolt doesnt come off that easy and it get stuck in there...u have to hit the metal part of it (not the threads just incause you fuk up) and it should pop out, if not a balljoint remover may be used or those pry things.
        Retro!
        Hater
          did you remember to lubricate? cuz i had mine installed by a professional speed shop and i dont think they lubricated it, then my rear control arm broke, so i have to wait till my new camber kit gets here before i have them lubricate what they were supposed to do because my steering wheel isnt returning.
            Your caster sounds like it's off.
            It's adjustable.
              really? okay i'll get that checked, got me kinda worried because of the hard steering. now i have to wait for my energy link end kit before i realign my car, i just changed the camber kit on whole car too. /sigh spent like f'in 450 dolla! anyways a word of advice, if you just wanted to put a camber kit on you dont have to take the whole control arm out, just take out two bolts up top and lightly pound the top of it until it shoots down
                End links are not supporting members, and have no effect on alignment.
                  you mean the stabilizer link bar right? that has no effect on alignment? well it's better to be safe than sorry, so i think im just going to wait until it comes. maybe i'll get my alignment checked to see how far off my camber is...
                    You can remove your sway bar and drive just fine, so no, no effect on alignment.
                      How'd the passenger side work out for you?
                      I have to do mine and you have to remove the fuse block to get to the top two bolts.
                        i had to remove the fuse box, disconnect the right side terminal, disconnect the negative on the battery just so i dont kill myself on accident...
                          No big deal. Four bolts hold the fusebox in place, and just push it aside.
                            Sweet
                            Nice work and write up
                              Did you notice any major difference in feel?
                              Also is a tie rod remover necessary in removing the ball joint? Did you notice special stools?
                              Thanks.
                              hahahahah
