well since everyone did 97-01 prelude cluster swap, am going to swap a cluster from 99 accord, something different
left is 99 accord cluster
right is 90 accord cluster
finish touch:
~~V.1.00~~
~~V.2.00~~
~~V.3.00~~ (current)
I DO NOT RECOMMENT DOING THIS SWAP FOR A FEW REASON:
-seatbelt light dont work.
-dome light only work when driver side is open.
-temperature gauge will work, but you need a 98+ accord temp sender. But in the 98+ accord, they dont use the sender only, I think they have some kind of temp detector,(hard to explain) but if you buy a temperature gauge, you are good to go.
-low fuel do not come on (i think it got to do something with the fuel thing).
and all the wire were plug in correctly, i checked it million time but still thing happen.
And for those who interesting in doing this swap, I have the diagram for the swap, but I cant post it up, If I post it up on the somewhere it will reside and you cant see anything.
finish touch:
~~V.1.00~~
~~V.2.00~~
