Ok, this car has had an annoying surge since i bought it. at first it was only when cold then it would stop. i swapped out the motor and still have the same problem high idle and surges from 800/1000 to 1500/2000 depending on the temp. except now it does it sll the time at any temp. I have viewed every thread on this site thus far and have found no fix that works for me yet except the possibility that my map sensor hose is in the wrong location. which i will check out soon. The throttle body is the only thing that came off the old engine and the gasket looks good. I replaced the map (which smoothed out the idle) I checked for vacuum leaks with starting fluid. I cleaned the iacv, and checked reference volts - good and it ohmed out correctly. I adjusted the timing and the throttle cable. the idle screw seems to do nothing for me. I bled the coolant and topped it off. no cel's. the tps is reading .48 at idle and roughly 5 at w.o.t. the reference voltage at the connector is 5volts. I replaced the o2 sensor no change. the buddy that i bought it from has a homemade cold air intake on it with a k&n cone style filter that is clean. I dont know if there is something vital missing from the old air hose??? the EGR valve is about the only thing I haven't messed with so far... can it cause idle woes like this? the car performs great off idle to redline, no hesitation or anything but damn when you come to a stop it goes crazy.
I had no idea it could cause a problem like that. Amazing that no one mentioned it before in any of the other "idle problem" threads unless I just missed it. I'll be reading that DIY right now and probably get on it right after work tomorrow. Thanks mike for getting me one more step closer to the solution to this oh, so annoying problem. I appreciate the compliment as well, and I will keep it up!
