Has anyone done an H22 swap and keep cruise control? How did you do it? Modify the H22 throttle cable bracket and use Accord cable? Or use Prelude cable and modify Accord gas pedal? Something else? Thanks in advance.
Throttle Cable
Ive still got CC. & yeah hes right. stick with the accord one
93 Accord LX Sedan (sold)
I know that.Originally posted by judonoh View Postcruse is attached to the gas pedal not the TB.
I ended up using the Accord throttle cable (which was obviously the only choice), moved the throttle cable bracket towards the throttle (attached to the intake manifold by only one bolt now), and added some washers to the pedal side of the cable to shorten it up. Pedal has proper free play and opens all the way. Should work once I fix my coolant leak(s). I don't see how anyone could say you don't need to do any of this to keep CC. If you look at the H22 and F22 throttle cables side by side, you would see that the adjusting nut is for the Accord cable is 2 or 3 inches closer to the throttle body.Originally posted by 91Accord-LX View PostYou shouldn't need to do anything to keep CC. It's a separate unit. Or am I not understanding the question properly? Are you wanting to swap yours for a Prelude one?
lol I dont think I had to modify the CC. post a pic of what you did
You don't remember?Originally posted by Night Wolf View Postlol I dont think I had to modify the CC. post a pic of what you did
afaik the dx/lx and ex accord throttle cables are different lengths.......Retired 1990 Accord LX Coupe
Project 240SX
Vouches: Bought from: smseagren83, phatdoughnut, uk - accord, lucid, iamnemo, accord_inspire, 2point6, chopstickz, djcaz_aom, roskoOriginally posted by chillin943anyone kno if i can just make a hot wire for v-tec off the horn??
It feels real snug, but I'm not taking any chances and will be doing just that.Originally posted by TheNextEpisode View Posthmm...
You might want to see about making something a little more sturdy for the throttle cable bracket, but yeah, good stuff.
