dashboard removal
    dashboard removal
    Has anyone ever removed a dashboard and took pics b'cuz I want 2 remove mine without screwing anything up.
    NEW CB
    new
    DARKCLOUD : 90 ACCORD EX MRT
    http://media.honda.co.uk/car/owner/m.../400/14-51.pdf
    14-51.pdf (application/pdf Object)
    thats the first part of it, i havent searched for the entire dash yet but i hope that helps
      Thanks hit me up if there's more 2 it.
      NEW CB
      new
        yeah i have been wondering how to take it out also because I recently painted my interior and I didn't quite get all the way in the front where the window meets the dash and you can notice it pretty well. I need some help.
          dude, ur car looks exactly like mine, i have the driver side caps off too. i thought it was mine for a second
            bump
              Buy a haynes. They have pictures for every step of the removal along with instructions. I found that I needed to take the steering wheel off too, which the manual didn't make too clear at first. But everything else was very clear. LABEL your screws and such that you use... DO IT. There are so many, on your first time you will get confused. I am.
              Click for my ride thread.
                It's really not that hard to do if you're patient and you'll want a friend there to help you with the actual removal when you're ready.
                If this is a '92-'93 disconnect the airbag first!!!!!
                To start of you'll take out the shifter console. Unthread the shift knob and take out 4 screws that hold it in.
                Then get your head in the floor board and look around behind the radio area while one of your hands turns the temperature control knob. The lever you see moving is the lever you disconnect.
                Now disconnect all three connectors by the fuse box in the driver's foot well.
                Pry off the emblem on the steering wheel exposing a 19mm socket that will need a long extension and remove the steering wheel a few inches and disconnect the connector on the back. (different procedure for '92'93).
                Once that's off you'll need to remove the plastic covering over the column with the 5 screws underneath.
                Now I can't remember exactly the number of screws to remove on this step but you'll figure it out. Just remove the signal/wiper combination switch.
                Once all of that is done take out the clock carefully to expose the mounting bolt. It is a 10mm bolt. There are two more on each side underneath the plastic plugs and the last two are on the metal bracket connecting the dash to the shifter tunnel.
                Just have a friend help you pull it out and you're good.
                I may have forgotten something but that's pretty much as good as I can do from memory.
                  You have to take off the bezel, which is like 12 screws or something. Before taking off the dash. I'd do the steering wheel and the plastic around shifter first.
                    search for the DIY.
                      Originally posted by rAwRLEN
                      search for the DIY.
                      I've never seen one...? Maybe I missed it. Would be nice if there was one.
                        I just did this
                        I will write a DIY sometime next week when I get back from Seattle. But it is really easy. The only tip I can give you off hand is to pull the top trim pieces and pull the dash from the driver side (steering wheel) first. Pull it STRAIGHT out not up or anything. That is the only way to get around the Key ignition. I would have to say the hardest part of the entire thing is getting the clock out without breaking it. I broke mine
                        Before
                        Nothing
                        After
                        If you have any specific questions before I write the DIY just ask
                        201 Whp H22a with bolt ons, see the progress from stock f22a to now HERE
                          Yeah, write it up. I liked the overall finish.
                          F22A1 = Now, NA : Soon, Turbo
                          My Member's Thread
                          Arcadia Green #14
                            i did it once, i'll never do it again so much wiring and stuff
                              dont forget the three wiring connectors under the radio... the overall procedure is really simple though. Just take your time, alot of stuff needs to come off, but its all simple... just need a phillips and a couple sockets.
                              label your shit... it will make it way easier. and the guage pod is tricky to get back in... play with it, it'll go.
                              RIP
                              Bought from : LosiRacer2, h22anow
