alright b4 you say research I have done alot of it on this site and honda-tech. I think the G22 is a good idea if you don't have the money for to buy a h22 and but it in ($1000 at least). My G22 is going to be N/A so I wanted to get some more compression since I heard just putting on a h22 head on a f22a will only get me about 9:1. I wanted to mild the head and get a 1 layer head gasket. I heard of some ppl decking the block but I'm not taking out the whole motor this is why I chose to go this route. As far as the rest of the build I use the
f23a head gasket..
h23 timing belt
h23 lower timing gear
h23 water pump
f22a water pipe is retained
let me know if this sounds right. I know I have to block off some holes on the block can you let me know about that. I'm try to get a jdm h22 type S because I know the cams are better then the h22a4 all comments welcome.
f23a head gasket..
h23 timing belt
h23 water pump
