Which HID Kit is the best to use and could i use them in my headlights without having to fit a projector in there? Also has someone done a write-up yet on how exactly you wire all this together?
Which HID setup to use
you dont need a projector..
if you have OEM housing you need a 9006 capsule.
projector housing = h3
jdm housing = h4
ill write more when i get out of class..Adam - Retired OG member from '03
Hm...well I am assuming that you already used the search feature using HID* as your search word. Most HID kits are plug and play though and come with all necessary wiring and even instructions. You can use your OEM housing as rebels has described. Just make sure you get a 9006 HID capsule. Honestly though there are a number of HID kits out there. I had one at one point and it is much brighter than stock, but not nearly as luminous as my retrofit."This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
FS Part out thread
koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
http://www.cb7tuner.com/vbb/showthre...10#post2119010
true, but you'll look like a rolling stadium with flood lights everywhere and just blind on coming traffic.Originally posted by rebelsyou dont need a projector..
05' S2000 GrandPrix White
93' Accord (Sold
JDM H22
Port n Polished Int Mani
Bored TB, maxed
MSD 6A
I/H/E
no cat
ive never had a problem with anyone flashing me cuz of my hid's and i have them on stock headlights...i love them. oh, and i have the catz hid kit
Originally posted by fizzbob7first off, don't be a sissy bitch.....that's what you're beingSo. Cal OUTLAWZOriginally posted by ACC0RD22no need to get sand in your vagina over this guys.
Well, that's for two reasons, 1- most people have gotten use to HIDs being so bright and your average driver has no idea how HID lighting works, they just know expensive cars have them. Most think its a bulb you can buy at Walmart, and dont even bother anymore.
2- scroll down to 90-93 Accord: http://faqlight.carpassion.info/car-tested-retro.htm
93' Accord (Sold
JDM H22
Bored TB, maxed
MSD 6A
I/H/E
no cat
if you adjust your lights correctly and install the kit correctly, you won't get anyone to flash you. you can also get the reflective shields that reduces the glare problem.
i would say use the HID's in a stock housing or JDM housing.. don't use aftermarket projectors.Adam - Retired OG member from '03
what do you guys know about the McCulloch HID kits Also i read about the kalvin temps and i think i would like to go with the 5000-6000k kit. Any suggestions? Oh and does anyone know what temp. the Acuras run with the "purple" hue?Last edited by 90AccordSiR; 02-08-2005, 03:56 PM.
All OEM manufactures, BMW, Acura, Cadi, Ferrari, Lambo, Mercedes, Ford ect use 4300K from Phillips or Osram/Sylvania. Anything above 4300K is worthless, you lose lumens the higher you go up in the scale. In other words, you won't see jack shit like you would with the 4300K. You would actually see better with the Slyvania Silverstars.Originally posted by 90AccordSiRwhat do you guys know about the McCulloch HID kits Also i read about the kalvin temps and i think i would like to go with the 5000-6000k kit. Any suggestions? Oh and does anyone know what temp. the Acuras run with the "purple" hue?
93' Accord (Sold
JDM H22
Bored TB, maxed
MSD 6A
I/H/E
no cat
