I would have put this on the recent balljoint thread that bcjammerx started, except the thread is old and so...here it is on a separate thread. I thought people would like to see it.
This video on youtube shows a guy separating the lower control arm from the knuckle using only a jack, his foot, and a closed end wrench. He jacks the lower control arm up and fits the closed end of the wrench between the b.j and lower control arm.
Then he drops the control arm and removes the jack, and just kicks down on the hub assembly. Leverage against the wrench separates the control arm from the b.j. and the wrench drops to the ground. The boot of the bj is untouched as long as you are careful in setting the wrench in there and watch as you drop the jackhead away.
Check it out, it's very cool! Who knows if it really works though:
http://www.youtube.com/watch?v=ISY8bGof3bQ
