Read up:
http://www.homemadeturbo.com/forum/i...threadid=35945
Unfortunately for the sohc's cam overlap is static and can't be changed with cam timing adjustments and is totally dependant on the amount of overlap the cam comes with. Whats too much overlap you say?...We don't know yet we have to wait for someone to dyno both the stock cam vs. the delta 272 regrind (or something similar). The good thing is that even if the 272 is less than or somewhat equal to the stock cam as far as power then it may "allow" for greater ignition advance. Lift and duration is commonly known as good for turbo engines but overlap was always considered bad...i haven't agreed with it being "bad" in a long time. Using a log style manifold's restrictions to an advantage is a brilliant idea IMO.
