so i have the box installed and wires ran. one by my ecu and one towards the fuse box. i cant find any info on how to connect it to the ecu tho. there is already a wire harness there. and do i need a fuse for the 12v power and where do i tap it into?
help with iab wiring. where do i connect and how?
Sorry I should have mentioned I have it ready and waiting. I pulled the wires yesterday. Now I just gotta swap the ecu and hook up the 2 wires for the Iab. But dunno how to make the connection to the ecu.....Originally posted by bcjammerx View Postyou will need the pt6 ecu. the ecu that came with your f22a1,4 won't work91 ex sedan
And now, new for 2012, a 93 ex wagon!
Paypal verified
Bought from: frootloops, 90accords, Agol
sold to: Agol
Originally posted by sdhardcoregamer View PostSorry I should have mentioned I have it ready and waiting. I pulled the wires yesterday. Now I just gotta swap the ecu and hook up the 2 wires for the Iab. But dunno how to make the connection to the ecu.....
So how has everyone else connected the wire to the new ecu? Also I have no idea where to tap into for power.
91 ex sedan
Paypal verified
sold to: Agol
Power is supplied to the solenoid by the ECU through pin A17 at the ECU. Ground can be supplied from any reliable body or chassis ground under the hood. Try and get the correct pin for the wire at the ECU, so that the pin locks into the connector, and supplies a reliable connection. This can be done using a section of wire from another harness if you have access to one, and is probably the easiest method. Hope this helps! I have submitted a link to a page with the ECU pinout information for your reference.
http://www.superhonda.com/forum/f55/...inouts-217405/Looking to buy: IAB Solenoid, and vacuum tank!
I thought it was the other way? I thought the ground was threw the ecu and the other wire connected to a 12v power supply. Anyone else have any thoughts or info? I did get a pin but now I want to make sure I do everything right. Still unsure which wire goes to the ecu and where the other goes, ground or 12v power?Originally posted by CB7LX93 View PostPower is supplied to the solenoid by the ECU through pin A17 at the ECU. Ground can be supplied from any reliable body or chassis ground under the hood. Try and get the correct pin for the wire at the ECU, so that the pin locks into the connector, and supplies a reliable connection. This can be done using a section of wire from another harness if you have access to one, and is probably the easiest method. Hope this helps! I have submitted a link to a page with the ECU pinout information for your reference.
http://www.superhonda.com/forum/f55/...inouts-217405/91 ex sedan
Paypal verified
sold to: Agol
__
