Ok well. I personally dont know where I would put this thread so I chose perforamce due to the fact that on what happened was nothing good and prolly killed performance.
So tonight. My friend decided to show me what happened when he used the directions of sea foam. What he did before was by using the brake booster vacuum hose, he sucked up about a half bottle and shut the car off. then 5 minutes later he was able to drive and burn it all away (gotta love the white smoke cloud for about 15 minutes fo driving)
Well as he tried this again. He sucked up a little less than half bottle again. Then tells me to shut the car off. So I do so and well. The engine stumbles and somehow its still on. I yank the key out and it still going. Now getting a bit irratic of an idle. He screaming at me to yank the key out and I show him the key out the window.
By now we both back up and notice the irratic idle even worse and now the brake booster hose shooting a 3 foot cloud of smoke, spewing out oil. Then the intake doing the same thing. And any other little hose that is conencted to the intake manifold shooting out oil. As we panic trying to figure out a way to shut it off. No luck. After staring cuz we had no idea what to do. 2 minutes have passed and it eventually just shut off.
Sitting and staring some more in confusion we clean up and I guess our conclusion was from the sea foam going into the cylinders and it being 100% petroleum. It ignited and managed to make the engine go in reverse. Causing the shooitng of smoke and oil from every part of the intake manifold and intake.
We finished cleaning up and grew the balls to try and start the car. Amazingly it did start and we took it for a ride. My friend has told me that car sint runnign the same. quite obvious. so we plan on ripping the intake manifold apart and clean it to the max. I just thoguh I would tell you of this horror story so you do not make the same mistake of sea foam. I'm still shaking from this experience and its not even my car.
Also a side note. It may not be a cb7. 91 integra acually, but this still may have happened to our cars. not cool!
