front speaker issues
    Could be the wiring but I'd say its the speaker. You could use a test light to see if you're still getting + and - to the speaker wires.
    ...adjust accordingly
      it could also be that one of the two cables connected to your speaker is not well attached to its respective connector on the speaker; and so sound would cut on and off if agitated by a bump on the road, or wind or something that could move the cable ever so slightly to break a connection. when you installed the pioneers, did you splice the stock wiring or use the speaker connectors? rust or corrosion on the cables/connectors could also be an issue. if the speakers weren't abused then i'd guess you've got a wiring/connection issue.
      My pictures/photos will return soon...
        Originally posted by yeamans17
        ok, so i sacked up and checked this out, the pass. door speaker had a poor connection. my solution was to hardwire the connections to the speaker tabs, problem solved.
        the drivers side speaker is a different issue all together, i checked the connections and they were fine, so i hardwired them anyways, but same thing, very week high signal, so i think the issue there is a blown speaker because i checked the signal coming into it and it was the same as the other side of the car
        most likely blown...look at ebayexpress for some new ones...very reasonable prices to say the least.
        Audi A4 2.8 Quattro Sport
