I can't seem to find the VSS (Vehicle Speed Sensor) anywhere and I need to change it out. Can anyone please tell me where to find it? A pic would be helpful but a good explanation would also help. Thanks.
Location of VSS?
Location of VSS?
I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
"Those who would sacrifice liberty for security deserve neither." - Benjamin Franklin
CB7: The Movie TEASER VIDEO
Tags: None
under the intake tube, on the top of the far back of the tranny, near the crossmember. it has two small power steering tubes looped from it to lines on the crossmember. two 10mm bolts to get the actual sensor off, one 10mm bolt and the two lines to get the whole assembly out. when taking the assembly out, its sealed in, so it gets tight, twist it back and forth while pulling, itll eventually come out.
its the little house shaped thing just to the left of the rear mount bracket
[img]http://www.****.com/pics/92exr/euror_removal/000_0310.JPG[/img]Last edited by cp[mike]; 08-21-2006, 11:45 AM.
afraid I can't make it out in the picture. can you circle it for me or add an arrow or something? thanks.I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
cool, thanks.I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
