There may be another thread somewhere, but I can't seem to find it. I'm gonna make this one a sticky, as wen can continue to add to it.
Please keep all posts on topic. Add suggestions, ask questions to have something further explained, and that's it. No comments like "well that's dumb!" Anything like that will be deleted (and I hate deleting posts, so please just don't do it!
) I will keep anything that addresses any major issues with a previous suggestion (safety and structural issues, for example)
If anyone can provide an estimated weight savings for anything listed, it would be appreciated!
The modifications will be classified in 3 levels.
Level 1 will be totally free. Basically just removal of stuff. Very little skill involved.
Level 2 involves purchasing lighter bolt-on parts.
Level 3 involves major modification (welded parts, etc). Anything that makes the car illegal to drive on the street is also in this grouping.
Ok, on with the info! I'll be adding to this as we go.
Level 1:
Back seat removal - 40lbs
Front passenger seat removal - 44 lbs
Spare tire removal - 28lbs
Jack removal - 8lbs
Trunk floor removal (board) - 5lbs
Power steering removal - ?lbs
Air conditioning removal (compressor, lines, brackets) - 84lbs
Cruise control removal (non-DX) - ?lbs
Audio system revoval (stock) - front speakers - 2lbs each
Door panel removal - rear - 7lbs each
Window regulator removal (all but driver's window, you need that to race!) - ?lbs
Carpet removal - ?lbs
Glove box removal - 6lbs
Center console removal - 2lbs
Rear seatbelts - 3 lbs each
Near-empty fuel tank - 6lbs per gallon
DRIVER weight reduction -
Headliner removal - ?lbs
Soundproofing tar removal - ?lbs
ECU holddown plate - 6lbs
Seatbelt ECU - 6lbs
Power antenna and motor - 14lbs
Underbody splashguards - ?lbs
Interior plastic trim - ?lbs
Headliner - ?lbs
Tailgate lower trim panel: 3 lbs
-267 so far! (going by things that EVERYONE has in their CB7)
Level 2:
Carbon fiber hood - ?lbs (stock hood is 54lbs)
Carbon fiber trunk lid - ?lbs
Carbon fiber front fenders - ?lbs
Lightweight racing seat - ?lbs
Lightweight exhaust system - ?lbs
Lightweight intake system - ?lbs
Lightweight battery - Stock - 43 > Odessey pc680 - 11 lbs
Lightweight radiator - ?lbs
Lightweight pulleys - ?lbs
Lightweight flywheel (aside from other performance gains, it DOES weigh less!) - Stock is 17lbs.
Lightweight wheels (I'm told 16" is best. Any info on the tire/wheel weight issue?) - ?lbs
Skinny rear wheels... You don't need much back there for a straight line!
Replace front seatbelts with racing harness - ?lbs
JDM Headlights (lighter than stock glass) - ?lbs
Stock Rear Springs + Shocks: 13.8 lbs each - Type II Rear Coilovers: 9 lbs each
Stock Front Springs + Shocks: 12.8 lbs each - Type II Front Coilovers: 8 lbs each
Level 3:
Lexan windows (or other lightweight materials) - ?lbs
Carbon fiber doors - ?lbs
Carbon Fiber rear 1/4 panels - ?lbs
Removal of bumper supports - ?lbs
Removal and/or replacement of door supports - ?lbs
The stock CB7 weighs roughly 2850lbs. What can we get it down to?
) I will keep anything that addresses any major issues with a previous suggestion (safety and structural issues, for example)If anyone can provide an estimated weight savings for anything listed, it would be appreciated!
Level 1:
Jack removal - 8lbs
Seatbelt ECU - 6lbs
Headliner - ?lbs
Level 2:
Level 3:
