#1 |
Moderator
INT: Automatic Short Shifter DIY
This is my first DIY so bear with me and my dirty interior, im a busy guy lol:
*notice* i am not held responsible, liable, whatever for anything you mess up trying to follow this DIY. If you screw this up you will need a new gear selector, so keep that in mind. tools needed: pipe cutter phillips head screwdriver (maybe) allen wrenches depending on your shift knob sorry if i forgot a tool This was done once already but was deleted due to a member no longer with us. So i am reposting and hopefully this helps some of us slush-box drivers feel a little more manly in our automatics I did this with a Pilot manual shift knob and matching boot from Pep Boys, but a majority of people have asked about look-alike knobs that actually depress like this one: ![]() this diy can be used for these types of knobs as well, since the same basic principle applies. *note* i find that when messing with the shifter its easier if you remove the interior panel surrounding the shifter and leave the shifter in the neutral position. First, lets learn how an automatic gear selector works in our cars. *note* pics are not of a cb7 shift knob standard automatic shifter: ![]() this can be removed via a couple screws located on the neck of the shift knob. Once it is unscrewed you simply pull up on the shifter. In some cases the spring and a white piece fall out of the shifter. dont worry about it, you dont need these anymore anyways. The Way Things Work: Heres what your looking at: ![]() when you push in the button on the side, the tapered slide rolls over a small wheel, gently pushing down the inner rod. ![]() The inner rod is locked upright and is only unlocked by pressing the brake pedal or inserting your key into the keyhole next to your gear selector. Point of No Return: For starters i didnt know how low i wanted to go, so i started by cutting off just the part with the wheel and a little from the outer rod. i used a Pipe Cutter i bought from Home Depot, much like this one: ![]() *note* make sure if you buy one that it is small anough to make full revolutions around your shifter rod assembly. Pep Boys sells a small Performance Tool one that i've used also. Now i was left with this: ![]() curious, i put the boot and shift knob on to see what it looked like: ![]() ugh, way too high. I realized i need to go really low. PLS READ THIS CAREFULLY: IF YOU ARE USING A PUSH DOWN TYPE KNOB: you need to make sure you have enough room so that when you depress your shifter to fully rake up and down thru the selections. IF YOU ARE USING A REGULAR MANUAL KNOB: you need to buy a knob that is held on with set screws, since obviously threaded type knobs will not work, unless you want to run a die-nut over the rod, which i dont think anyone wants to do. Set the knob on the inner rod, push your brake pedal, push down on your knob and SET THERE. then try raking up and down through the selections I dont have any way to tell you how much to cut, since every application will be different, so take off small increments until you are happy. I ended up with this: ![]() I also removed the plate with the letters to allow my boot to "sink in" Heres my final product: ![]() i love using the manual knob because i dont need to use my brake pedal to pull the car down into reverse, or from neutral up to reverse. HOWEVER, i cant recommend this to anyone because im not gonna be responsible for you pushing it into reverse on the interstate hope this helps, pm me with any questions
__________________
![]() CB7tuner.com Appearance Specialist - PM me with any bodywork questions |
#2 |
CB7tuner Member
I did a similar set up in my old cb7 with auto tranny, I didn't cut the shifter down but I used a manual shifter boot and the square metal piece it screws right into place. the only problem though is if you manually shift you cb7 like i did the boot got really tight when you pulled it into 1st gear. But yeah write up is really good man, kinda wish i had an auto so i could do it.
__________________
vouch for:924dr, sn2bh22cb7, soysaucecb7, ecto1, PRIMESNIPER,2.2litrebeater,turbowagon94, losiracer2,jacobuchanan140, tommi, dannyd |
#3 |
CB7tuner Member
well thats definetly different lol
__________________
![]() My s13 Ride Thread>>><<<My Rx7 Ride Thread If you don't know what your talking about, please stop talking about it. |
#4 |
Accord of the Month: August 2008
Hmm very interesting...something to think about after my cb comes out of the shop..
__________________
accordtypeR aka Seve aka The Godfather. ![]() My Old Baby....................My New Baby SOLD TO..grumpy93, iceplaya123, slr_theking, tn_accords |
#5 |
CB7tuner Member
Very nice
Im thinking about doing this but how did you get the shift boot to fit |
#6 | |
Moderator
Quote:
the one i bought was elastic all around the bottom, i removed the panel with the P,R,N,D4 etc.... and hooked it around the screw holes for that panel where i could. Im not sure, but i think manual center consoles have screws or something to hold their boots in place, you might be able to source one of those from a member on here and get an oem replacement. Or i think some ebya ones have ties on the bottom. either way, its not hard to make one fit.
__________________
#7 |
CB7tuner Member
I was wondering if this shifter would work on an automatic? http://www.racinglab.com/momshadshifk.html
Does anyone have any idea how it could be done? Thanks, Hieu
__________________
#8 |
Contributing Member
It should. There's only 2 kinds of ahift knobs. Ones with a push-button(for automatics) and ones that are just a knob(for manuals). He used a knob meant for manuals, he just made sure he could push it down in order to unlock the rod to move through the gears. Depending on how tall the knob is, no modification may be needed. Plenty of ppl have just slapped on a boot and manual knob.
BTW '93.....How the hell do you the e-brake handle?!? I cant find that anywhere...
__________________
#9 |
CB7tuner Member
dude that is sick!!!! im doing that this weekend, how much did the pipe cutter cost you? might change to a manual shift knob too
#10 |
CB7tuner Member
where did u put the sports button?
#11 |
CB7tuner Member
naw...the sports buttom don't really make a different...is it?
__________________
"6-19-09".................................................. ........ "11-19-09" ![]() ....CB7-DAILY....................AE86-HIBERNATE.....................CB7-PROJECT? |
#12 |
CB7tuner Member
Thanks greencb7inkc,
I'll do a little more research and try it out. I'll make sure to share the info find. thanks, Hieu
__________________
#13 |
CB7tuner Member
make sure that whatever manual knob you get uses 3 set-screws on the bottom to hold it on rather than screw-on types. almost all of them at autozone/oreily's/pepboys are the set-screw types, tho.
__________________
![]() Click for my Member's Ride Thread One8Seven Car Club Executive form. function. style. truform. Bisimoto H22/H2b Header Group Buy. SIGN UP!!! |
#14 |
CB7tuner Member
Nice I love it. Short shit on an autoooo...beautiful.
#15 |
CB7tuner Member
could you measure how much you cut off of the shifter just so i have an idea of what yo cut
#16 |
Contributing Painter
i got inspired by this thread and went to the shop and did this tonight.
i cut mine with a hack saw and cutting wheel.. i stole the boot thing out of my other accord,, and i put my sport mode button right in the center,, thats the only switch i had around,, it will be improved.. ohh and i welded the little bar thing inside down, and put three welds around the outside and beat my shifer nob on it so it wouldn't move.. ohh and i know i am not the best at welding lol. but i love the feel of it now.. it kinda makes me wana shift.. it took me 2 hrs to do, because i had to rerun the sport shift thingy and i was just being verry cautious on everything.
__________________
![]() the EX revelation http://www.cb7tuner.com/vbb/showthread.php?t=75529 http://www.cb7tuner.com/vbb/showthread.php?t=93794 Yes Keele ... is my last name. it's pronounced like "Kill" |
#17 |
CB7tuner Member
great diy. so its fine to have the center shaft that you would usually have a button on, compressed all the time?
__________________
MRThttp://www.cb7tuner.com/vbb/showthread.php?t=17383 92-93 ex wagon (cb9) parts car TOMMI
#18 | |
Quote:
but WARNING!!!!!!!! if you have kids do not do this, because it can be nocked out of gear without any trouble at all. you just have to be a good driver who doesn't have these kinds of worries to do this.
__________________
#19 |
CB7tuner Member
im doing this today an will post pics when im done
#20 | |
Quote:
__________________
| Thread Tools | |
| Display Modes | Rate This Thread |
