knock sensor question
    That's pretty much what would happen if the engine was revved up in neutral... no VTEC, and it cuts out around there.
      yes thats what I was doing i was giving it gas while in neutral ,but I wasnt going crazy doing it.. So if you are in neutal and give it gas it will only go up to 6800 rpm instead of 7200
        This thread just made my head hurt.
        Keep an Eye on my Coupe. Click the Pic
          Yeah, that's why you're not hitting VTEC, and why it stops then. Try doing it while you're driving it... in gear.
            me too
            it reminded me of people whe remove their thermostats so the car won't overheat or drive with the hood partially open for the same purpose
              this + your engine must be warmed up. Drive it nicely for 5-10min than take if for a longer run and you'll be able to hit 7200
                Thanks for all the help, That what it was i needed to be driving the car.
