#1 |
CB7tuner Member
civic radiator
can you use a civic half radiator on an accord and still retain a/c? i was just wondering cuz i a picture of a cb7 with a civic half radiator...unless they make accord half radiators...
#2 |
CB7tuner Member
what does your ac have anything to do with the rad ?
#3 |
CB7Tuner Member
Location: Dallas, Waco, And now SIUC for school I'm going worldwide bitches!!!
I dunno if you can retain AC but you can try. If it doesnt work out you will know. What type of setup you goin with?
__________________
![]() The New-ish Ride My old Ride Hear my Vtak!!! MK3 Member #3 I piss off people for fun. IA 08 Sunburn Victim #1 |
#4 |
CB7tuner Member
What I wonder is would a half radiator suffice to keep your engine cool enough for regular use let alone running the ac, even if you can get the lines to work out.
#5 |
CB7tuner Member
eh... its pushy with oem radiators.. but with a dual core your fine... the civic boys with deuces run half sizes all day... as for ac? i doubt it... i want one... more room for turbo :P
__________________
![]() SOLD! |
#6 | |
CB7Tuner Member
Quote:
__________________
#7 |
Contributing Member
it would be a good idea to get a dual core one, im running a oem civic one while it doesn't overheat the fans kick on to much since its the temps started getting hotter in tx.
__________________
#8 | |
CB7tuner Member
Quote:
#9 |
CB7tuner Member
im going with a turbo set up but will a dual core fit in there with an h22 swapped in? i still want to retain ac though...
#10 | |
CB7tuner Member
Old thread here getting bumped. I have the same issue. H22 turbo, kept a/c, overheats like mad on street driving. Has a Mishimoto half size radiator (dual core I think). Not sure where to go from here. Lil help oh guru's of the CB7?
__________________
Quote:
![]() My ride: http://www.cb7tuner.com/vbb/showthread.php?t=187897 |
#11 |
Contributing Member
Aftermarket D series radiators are dual core and the B series radiators are triple core.
Always go for the B series especially when going turbo. And maybe consider changing to an aftermarket thermostat and fan switch
__________________
RACE WUT U BRUNG! ![]() |
#12 | |
Moderator
Quote:
__________________
Car Safety / General Servicing Checks --------Basic suspension checks My 5.7 LS1 Holden Ute If at first you don't succeed, Try again. Don't give up too easily, persistance pays off in the end. |
| Thread Tools | |
| Display Modes | Rate This Thread |
