#21 |
CB7tuner Member
wait so the screws just get screwed to the shaft?is this safe?...it doesn't try sliding up any?
__________________
~CB7 Phoenix~ (picture missing help me get a new one )The California White Tux *and its alive!! hahaha* *under construction*M.R.T: http://www.cb7tuner.com/vbb/showthre...=1#post1689652 *changes soon to take over* |
#22 |
CB7tuner Member
no it doesnt slide up and down because they are set screws nmeaning that the tighter u put em on the more steady it is
__________________
![]() ..."CLASSIK"-CB790 ex... {UNDEFINED}My Classy but Sick (Classik) Black on Black Members Ride Thread |
#23 |
CB7tuner Member
ohhhh ok, well thanks very much
__________________
#24 | |
CB7tuner Member
Quote:
__________________
Once a CB7tuner always a CB7tuner
#25 |
CB7tuner Member
Ok i just got a shift boot for my auto. how do i tuck it in?
__________________
#26 |
CB7tuner Member
remove four screws on the sides of the center console, place shifter in neutral*may need to use key to do so*then remove, if the knob is already off or its an aftermarket skinny knob then you unhook the connecter for the shift position lights unscrew the four screws holding the plate,lift up to remove,then place boot over that area replace the center back on, fix anything needed replace the screws to hold on the center console and replace your knob or if you didn't have to remove it then your already done.^_^
__________________
#27 |
CB7tuner Member
what is the sport/overdrive button even really good for??
#28 |
CB7tuner Member
nothin i just unhooked mines it doesnt do shit anyway
__________________
#29 | |
CB7tuner Member
Quote:
shifts a lil later than normal, you could wire it to a button up to you
__________________
![]() UNDERGROUND SOCIETY GET DOWN OR LAY DOWN
#30 |
CB7tuner Member
I got the 2 screws on the shift knob off but I cannot remove the knob. I got that sport button which the wire goes down to the bottom which might prevent removal. Do I need to remove the sport button before the know can be removed?
Thanks. |
#31 | |
CB7tuner Member
Quote:
__________________
![]() KEEP IT NICE, NOT RICE |
| Thread Tools | |
| Display Modes | Rate This Thread |
