Go Back   CB7Tuner Forums > Beginner forum -- New members post here! > Beginner Appearance
Old 12-30-2012, 11:13 PM   #1
$oy-Cabrona87
Newcomer
$oy-Cabrona87 is cool... so far.
Negative camber good or not?
Been thinking of setting a my accord on negative camber eventually. I would like to know if setting the accord on a negative camber affect the tire wear, scrape on the fender or other issues. Or is it better overall to just lower the accord. Would like to know since the negative camber looks pretty awesome but don't want any issues that come along with it.
$oy-Cabrona87 is offline   Reply With Quote
Old 12-30-2012, 11:19 PM   #2
H311RA151N
Silver Member
H311RA151N seems to have made some friends! H311RA151N seems to have made some friends!
Its all about the look. Not the function of the car. Tires wear like shit, depending on how much negative camber you have you can burn through a set of tires in a couple hundred miles.
Its not for the daily driver AT ALL. It handles like ass too.
Too much negative camber and you will have to roll the rear fenders.
Just get some quality struts and springs. It will ride better, corner better and look better. You will notice a massive improvement over the stock springs/struts.
Neuspeed, Tein, Ground Control, Eibach are some good springs, Good struts are Konis really. What type depend on what type of spring you want.
How low would you like to go? Coilovers might be an option for you too depending on what your looking for.
__________________
Quote:
Originally Posted by gloryaccordy View Post
Holy fuck, it's the weekend man.
H311RA151N is offline   Reply With Quote
Old 12-30-2012, 11:21 PM   #3
deevergote
Don't call me dude.
deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool...
Send a message via AIM to deevergote
It will destroy your tires over time, especially if you don't get an alignment.
__________________
deevergote is offline   Reply With Quote
Old 12-30-2012, 11:23 PM   #4
reklipz
CB7tuner Member
reklipz seems to have made some friends! reklipz seems to have made some friends!
Any amount of negative camber that you add that is useful for cornering/handling will be very hard to see visibly.
__________________
reklipz is offline   Reply With Quote
Old 12-30-2012, 11:26 PM   #5
deevergote
Don't call me dude.
Correct. And anything you can see will cause you to ride on the sides of the tires... not very safe when you have tread, extremely unsafe after a few thousand miles when that tread has worn out. The intended contact patch of a tire is in the center. With extreme negative camber, that contact patch becomes the inner edge.
__________________
Old 12-31-2012, 12:27 AM   #6
HappyGilmore
AKA Gillymomo
HappyGilmore seems to have made some friends!
Send a message via AIM to HappyGilmore Send a message via MSN to HappyGilmore Send a message via Yahoo to HappyGilmore Send a message via Skype™ to HappyGilmore
As close to 0 as you can get, some negative camber (not a whole lot -.5 or so) is needed but not a severe amount even when lowered (corrected by camber kit) is your best bet. Safe and done right is always the best way.
__________________
The CB7 Collector.
92 LX Coupe F22A1
97 LX Wagon 5-Speed F22B2
92 EX Sedan F22A1
Quote:
HappyGilmore is offline   Reply With Quote
Old 12-31-2012, 02:40 AM   #7
H311RA151N
Silver Member
^^^ Yep
Name brand springs, depending on the drop Koni Yellows or Oranges, Ingalls front camber kit, Megan or SPC rear camber arms, and new strut mount bushings. Then take it to have an alignment.
Any lower than 2.75" Id suggest looking at Function & Form Type 1 Coilovers. Mainly because after 2.75 and lower most people are wanting to slam the car and are not concerned as much with handling.
Still with the coilovers the Ingalls front camber kit and the Megan or SPC rear camber kit is needed along with an alignment.
__________________
Old 12-31-2012, 03:11 AM   #8
bassrock234
CB7tuner Member
bassrock234 is cool... so far.
I'll keep it short because this always starts huge arguments that go on and on. But a little negative camber will help with handling, but only to a certain extent. Also, a little negative camber won't hurt your tire wear, but be aware when you change camber you need to get an alignment, as the toe will change and toe will destroy tires faster than camber. I've run -2 camber on my trucks with no ill effects on tire wear as long as the toe is kept straight. Weight distribution also makes a difference. My accord has -3.3 camber in the front, and it wears the inside of the tire a bit even with the toe correct. The rear has easily -6 with almost no camber wear at all.
__________________
I wish I could trade my heart for an extra liver, just so I can drink more and care less.
bassrock234 is offline   Reply With Quote
Old 12-31-2012, 03:19 AM   #9
H311RA151N
Silver Member
Quote:
I agree mostly. Toe kills tires worse than camber. And slight negative camber will help handling.
Im lowered on STRTs and Eibach Pros with a proper alignment.
No camber kit.
My front is -2.25 and the rear is -1.86
Im wearing tires pretty bad in the front but in the rear its not wearing abnormal at all. Im running 80,000 mile Good Year Viva 2s 195-60R15.
Alignment machines will show the numbers up in red anything + or - .75 meaning for the opperator to fix.
-3.3 is way to much negative camber for wearing tires. Unless your hellaflush or dont care. -2.0 I wouldnt be content with either. But by the pic in your sig I can see why you like it that way. It looks bad ass!
__________________
Old 12-31-2012, 03:28 AM   #10
bassrock234
CB7tuner Member
well with the trucks the -2 was natural camber, and they dont make camber kits for them. My car had -6.3 natural camber before I put the camber kits on, they brought it down to -3.3. The rear I had to run that much camber to fit the wheels (and honestly I dont have an exact number for the rear since it hasn't been on a rack since then) But I don't really beat my car or run it hard so I don't mind the camber so much.
To the op, just drop the car, it will look way better and you'll gain negative camber whenever you do drop it. Stock height with negative camber would just look goofy IMO
__________________
Old 12-31-2012, 04:03 AM   #11
H311RA151N
Silver Member
I have a friend with an 80s Chevy 4x4. He has like -4.30 negative camber in the front. He has a solid axle and says the only way to fix it is by replacing the worn ball joints. That would suck.
__________________
Old 12-31-2012, 08:25 AM   #12
KLEENKREW
CB7tuner Member
KLEENKREW is cool... so far.
I have my drag car set up i with .5+ in rear and -.5 in front so that when we launch and under WOT loads my alignment is as close to 0 all amount the board.
So it just goes to show you that everyone sets their alignment up to their specifications and what they want out of there car.
Some European vehicles come factory with neg camber. So it is fine to a degree.
IMO there is a point where to much is ridiculous though
KLEENKREW is offline   Reply With Quote
Old 12-31-2012, 08:59 AM   #13
H311RA151N
Silver Member
Like I said, The front on mine is -2.25 and Im wearing tires out. I dont remember what my toe is but it was green on the chart which is good.
Here is the front:
And here is the rear:
__________________
Old 12-31-2012, 09:57 AM   #14
TAMPA
Bronze Member
TAMPA seems to have made some friends! TAMPA seems to have made some friends!
Damn, its looking pretty bad.
TAMPA is offline   Reply With Quote
Old 01-01-2013, 05:38 AM   #15
allentang14
Newcomer
allentang14 is cool... so far.
its not bad i just go to the junk yard and get new tires every oil change its $50 where i stay at
im -5 in the front and -4 in the rear, d2 coilovers slammed to the ground & spc front balljoint & godspeed camber kit
but i just got my alignment so the toe is fine, haven't needed new tires yet since november
allentang14 is offline   Reply With Quote
Old 01-01-2013, 03:13 PM   #16
H311RA151N
Silver Member
The OP is concerned with tire wear. If that works for you, great. But I wouldn’t go around recommending people change tires every 3000 miles instead of doing a proper drop with the right camber and keeping a set of tires for a year or two.
__________________
Old 01-01-2013, 03:15 PM   #17
deevergote
Don't call me dude.
Especially with junkyard tires... they could be mismatched, dryrotted, internally damaged, etc...
For a daily driven car, I don't see the sense in making it dangerous just to look "cool" (and "cool" is a relative term... because people that realize how dangerous it is don't think you look cool at all!)
__________________
Old 01-01-2013, 03:34 PM   #18
H311RA151N
Silver Member
Function, reliability, cleanliness, maintained, improved. Those are what I see when something is "cool".
That’s what went through my head. I got a junkyard tire once that ended up being dry rotted. It blew a few days after putting it on and took my fender well out and ripped all the wires from the engine fuse box to the in car fuse box. That was a PITA to rewire. All the wires were bare, fuses were blown, and shit was melted.
This was on a newer Hyundai.
__________________
Old 01-01-2013, 03:47 PM   #19
HardInThePaint
CB7tuner Member
HardInThePaint seems to have made some friends! HardInThePaint seems to have made some friends!
Quote:
You have camber kits yet your shit still has all this negative camber, it looks like you just slammed your shit with no kit at all... Whats the use of purchasing the hardware when you don't use it?
__________________
HardInThePaint is offline   Reply With Quote
Old 01-01-2013, 08:45 PM   #20
H311RA151N
Silver Member
Can a camber kit even correct a 5/4 drop?
__________________
Tags
92 accord negative camber
