Old 11-30-2017, 09:11 PM   #21
sonikaccord
Contributing Member
sonikaccord seems to have made some friends!
Quote:
Originally Posted by kratemertyl View Post
got ya. 0v. I was thinking ov.
tomorrow I'm going to take all this info and start over.
hopefully with this I can narrow it down.
in all actuallaity from all I have done its prob enough info to say its the ecu.
do u think if I took the ecu (as far as the main relay is concerned) out of the equation and sent 12v to yellow and 12v to yel/blk it would run?
Most definitely! Just go all out and get a racecar switch panel for those wires.
__________________
sonikaccord is offline   Reply With Quote
Old 12-01-2017, 06:27 PM   #22
kratemertyl
CB7tuner Member
kratemertyl is cool... so far.
had a minor difference between your description of the relay and what I actually have. I don't have a #4 terminal heres how mine reads
7=yellow (fuel pump power)
5=blk/yel (12v activated by key)
3=yel/blk (wire that leads to injector resistor box and o2 sensor)
1=yel/blu (constant 12v to relay)
8=grn/blk ( to ecu)
6=blk/grn (to clutch interlock I think)
2=blk (ground to ecu and to ground at rear of motor)
ok so with all that info heres how today went down,
turned key on and had 12v at 1,3 and 5
jumped power to yellow, fuel pump runs, motor turns over but will not fire
for some reason I started looking at the clutch interlock. the schematic shows it having a blu/red wire from the fuse box fuse #9
checked fuse, fuse is good and reading power on both sides but no voltage at connection of switch.(scratching my head)
took off the switch
wont turn over.
tried applying 12v to the other wire of the switch which is blk/grn
I hear a relay click
turn key, engine turns over but no fire
look at how the alarm was tapped into this blu/red wire with two wires.
cut them out of the loop and connect blu/red back together
still no start
try connectiong those two alarm wires together
no start
applied 12v to those alarm wires and 12v to blk/green at clutch interlock
turns over but wont fire
apply 12v to yel at main relay, fuel pump runs, apply 12v at blk/grn, relay clicks
still wont fire
then all of a sudden (think I may have messed up the relay) when I turn the key the fuel pump turns on
yay right?
no
still wont fire
when the key is turned on the pump dosent prime and then shut off, it jus goes continueous
still showing 12v at yel/blk
so u would think it should start
reading good fuel pressure at rail.
even hit the TB with a little ether.
nothing.
I'm guessing no spark
didn't get around to pulling a plug and checking. its seems pretty obvious that there is none.
I'm even more confused then I was before
because according to the schematic it should all be good now
I see on there though that the blk/grn travels from the clutch interlock switch to whats refered to as the PGM-FI elec control unit.
what the hell is that?
I would check for voltage at the resistor box but I cant seem to find it after my wire tuck.lol.
I origanlly suspected this because I know its on the driver side and that's where I got hit. so even though the car ran after the accident I wondered if maybe the wire had interference somewhere around there.
but then I figured that wouldn't be causing the fuel pump not to turn on.
this sucks, its perfect weather for the car right now
#carforsale
__________________
kratemertyl is offline   Reply With Quote
Old 12-06-2017, 11:04 AM   #23
G. Wiffington
CB7tuner Member
G. Wiffington is cool... so far.
Have you tried starting it up with another ECU?
G. Wiffington is offline   Reply With Quote
Old 12-08-2017, 07:05 PM   #24
kratemertyl
CB7tuner Member
No, still trying to get my hands on one.
__________________
Old 12-22-2017, 09:39 PM   #25
fleetw00d
Contributing Member
I had this issue last week in my 90. Cranked, but wouldn't fire, couldn't hear pump running. Did much of the troubleshooting you're describing. Installed a spare ECM I had and she fired right up.
__________________
90 LX 4dr 5 spd 369,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
93 LX wagon auto 250,000 MRT: http://www.cb7tuner.com/vbb/showthread.php?t=208490
92 EX coupe auto 168,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=205114
92 EX coupe auto 190,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210341
LOTS of CB7 parts for sale http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 12-28-2017, 12:30 PM   #26
PakaloloHonda
Contributing Member
PakaloloHonda is cool... so far.
Send a message via AIM to PakaloloHonda Send a message via Yahoo to PakaloloHonda
wow .. went to rep you on this Son, but it says that I gotta spread it around a bit more.
Someone hit this cat up for me .. THIS is what this site is all about!
Quote:
Originally Posted by sonikaccord View Post
I drew a *really* crude schematic. I hope it helps!
__________________
PakaloloHonda is offline   Reply With Quote
Old 02-07-2018, 09:26 AM   #27
kratemertyl
CB7tuner Member
Update,
Found a cb laying behind some tire shop. Politely asked the old man to borrow the ECU and he generously agreed. Plugged it in to my car and the fuel pump turned on
Ordered a p28 off eBay.
It came in yesterday. Gonna pick up a socket kit for the hondata and get this thing plugged in. More to come next week.
__________________
