Ru
THANKS TO ALL OF YOU FOR THE MOTIVATION
MY OLD SETUP
NEW SETUP SNEEK PEEK
SUSIE
Sneek Peek Of My Coupe Before
RECENT
*STROKER ON BOOST
95 JDM Honda preLude H22A/ 36k miles
Garrett GT3582R
Dual Ball Bearings
CUSTOM TOPMOUNT MANIFOLD
Darton sleeves (88mm bore)
F22 95mm Crank
H22 Eagle ESP H beam Rods
JE custom 88mm pistons
Supertech DUAL VALVE SPRINGS
Supertech TITANIUM RETAINERS
H22 Type S Cams
Fully gutted stock mani plus 2 extra plates
74mm throttle body
Tial 44mm Waste gate 13psi Spring
Precision Turbo 1000cc Fuel Injectors
ARP rod bolts
ARP headstuds
KING's main/rod bearings
Innovative Mounts H22 Alternator Relocator
GREDDY Turbo Timer
BCU Electronic Boost Controller Good Shit
HKS Blow Off Valve
Fluidyne Half sized radiator
FLUIDYNE RADIATOR FAN MOUNTING KIT
COLOR=Red]ESP [/COLOR]Motor Mount
AEM adjustable Cam gears
AEM High Volume Fuel Rail
AEM Fuel Pressure Regulator
B&M fuel pressure gauge
H23 Manual Tensioner conversion
KaizenSpeed balancer shaft removal kit
F20B Crank Pulley
2 Walbro 255lph fuel pumps one intank and one inline
GM 3 Bar MAP Sensor
CUSTOM OIL CATCH CAN(Custom Fab By MARCOS)
AUTOMETER BOOST GUAGE
AUTOMETER WATER TEMP GAUGE
AUTOMETER Oil Temperature gauge
Summit G1200A Battery Box Relocation Kit (IN THE TRUNK)
Painted Block/Head ( Cast Iron Aluminum Paint)
Painted wrinkle red TB
Painted wrinkle red WASTEGATE TOP HOUSING
IM Butterflies Removed
Painted Wrinkle Red turbo Housing
Race thrust washers bearing
BRAND NEW FULL ENGINE GASKET SET
Brand New Water Pump And Timing Belt
Steal braided fuel line -8 an
Huge Front Mount Intercooler ( 31x12x3 )
PROCOMP 14" INCH ELECTRIC RADIATOR FAN
Homemade custom fan shroud (big plus )
K&n Air Filter
DEI Heat WRAP
3" Intercooler Piping
3" DOWNPIPE With Flex Pipe (Custom Fab By Marcos)
DYNOMAX ULTRAFLOW WELDED MUFFLER 3" IN/OUT
*TRANSMISSION/DRIVETRAIN
Auto-to-manual 5spd conversion
ESP Motor MOUNT KIT
95 JDM Honda Prelude M2B4 (Limited Slip Differential) transmission
Painted tranny
Competition Stage 4 Clutch
Fidanza 7.5 lbs Flywheel
Gator axles
*EXTERIOR
SHAVED Body Molding
SHAVED Antenna
Xenon Side skirts
Sigma Rear Lip
Carbon Fiber Hood with pins
92-93 Sedan Trunk Swap.
Custom Smoked Tail lights
Custom 4pcs SEAMLESS WINDOW VISORS
Custom Flush mount spoiler(made by me)
Custom Rear Window Visor WITH 3RD BRAKE LIGHT(made by me)
CUSTOM FRONT/REAR TOW HOOK
Jdm Cb3 side markers Smoked
EDM TRUNK LICENSE PLATE GARNISH
EDM CB Headlight Washers
EDM License plate (Holland) authentic Set
89 crx AMBERSmoked front bumper signal
JDM one Piece headlights
Rear view camera
*INTERIOR
98 ACURA CL Maplight
Sparco Torino Racing seats
92 SE Dash with airbag
92 Se leather Door panels
Painted interior Black
92-96 Prelude Black Seat belts
YEAMANS'S SHORT THROW SHIFTER
JDM CB3 ARMREST
BROADWAY REAR VIEW MIRROR 400MM FLAT
Custom Detachable steering wheel
Custom Roll Bar
THIRD BRAKE LIGHT REMOVED
Mas Power interior Glass Mount antenna
Double din dvd nav Player with 7" screen
Custom pedals
*SUSPENSION/WHEELS
TR TRACTION CONTROL BAR
FULL DROPZONE COILOVER SYSTEM
Front Strut Bar
Rear upper Strut Bar
Rear Lower Strut Bar
BBS STYLE 5's 090 RC custom painted
17x8 +20 offset
18" SSR VIENNA DISH RIMS ( 8" /+31 /9"/+37 )
old
18" Daz Matiz wheels old
*BRAKING
Upgraded Big brake kit
Painted Red Caliper
Cross Drilled/Slotted Rotors
*LIGHTNING
85K H.I.D KIT
ONE PIECE HEADLIGHT
SMOKED REAR FOG LIGHT
89 CRX BUMPER SMOKED BUMPER SIGNALS
SMOKED CB3 SIDE MARKERS
*AUDIO/ELECTRONICS
Upgraded Front door panel speakers
Upgraded rear speakers 2002 accord
door panel mounted tweeters
Pioneer Avic D1
rear view backup camera
*Future Plans
RECENT
*STROKER ON BOOST
Garrett GT3582R
Dual Ball Bearings CUSTOM TOPMOUNT MANIFOLD
F22 95mm Crank
H22 Type S Cams
74mm throttle body
ARP rod bolts
ARP headstuds
GREDDY Turbo Timer
HKS Blow Off Valve
F20B Crank Pulley
GM 3 Bar MAP Sensor
K&n Air Filter
DEI Heat WRAP
ESP Motor MOUNT KIT
Painted tranny
Gator axles
*EXTERIOR
SHAVED Body Molding
SHAVED Antenna
Xenon Side skirts
Sigma Rear Lip
Rear view camera
*INTERIOR
JDM CB3 ARMREST
Custom Roll Bar
Custom pedals
*SUSPENSION/WHEELS
Front Strut Bar
17x8 +20 offset
old 18" Daz Matiz wheels old
*BRAKING
Painted Red Caliper
*LIGHTNING
85K H.I.D KIT
ONE PIECE HEADLIGHT
*AUDIO/ELECTRONICS
Pioneer Avic D1
*Future Plans
MY OLD SETUP
