Go Back   CB7Tuner Forums > Parts & Performance > Performance Tech > Forced Induction
Old 04-10-2011, 12:18 AM   #1
project93
CB7tuner Member
project93 is cool... so far.
Potentail disasters
SO i have a question I have a 2nd block im not using and ive completely tore it down
Will i be able to use Stock pistons with this setup. Does anyone see any flaws potential disasters or issues.
Turbo Kit:
Holset HX35 turbocharger
obx turbo manifold
Custom 2.5" aluminum charge pipes [hot and cold]
Stealthmode Oil line kit
Silicone couplers / T-bolt clamps
Precision 600hp FMIC 31.5x8x3.
hondata
GReddy Type RS blow off valve
Tial 44mm external wastegate
Engine
F22A6
Bisimoto CAM lvl 2
Bisimoto Retainers and springs
Bisimoto Valves
block guard
ARP Head studs
New OEM bearings/rings
OEM Honda headgasket
port matching
valve porting
block will be heat tanked,
Tranny
h22a 5spd transmission
Competition Clutch Stage 4 clutch kit
Competition Clutch 12lb Flywheel
interior
autometer oil pressure gauge
apexi turbo timer----
Roll cage
stock seat
G-Force 5pt SFI approved harness set
suspension
traction bar
dc sportfront strut
password jdm rear strut
hasportmotor mount
hasport axels------
tein Coilovers----
MSD 6Al ignition ---
NGK 8 series spark plugs .020 gap---
Air Induction/Fuel:
obx air intake-----
ITB-------
RC 750cc injectors
Walbro 255lph fuel pump
Spoolin' Performance oil catch tank
Golden Eagle vacuum manifold
Generic breather filter
COOLING:
Custom mounted Aluminum Half-Size Del Sol dual-core radiator--------$65
Fail Safe 180* thermostat
One 12" slim electric fan
__________________
Click to see ride.↓↓
project93 is offline   Reply With Quote
Old 04-12-2011, 02:43 PM   #2
DKRM
CB7tuner Member
DKRM is cool... so far.
KM's/condition of the block would help, are you rebuilding it with oem pistons and rods or using them as-is? it looks like a solid build, but the psi you decide to run and the tune you get will determine the life of your engine,
good luck !
re read it and, with your set up i would go with forged pistons and rods, everythings apart already so now would be the time instead of later, imo
DKRM is offline   Reply With Quote
Old 04-12-2011, 03:35 PM   #3
bruno8747
Contributing Member
bruno8747 is cool... so far.
Send a message via AIM to bruno8747
Why even use a HX35 if you are gonna use stock pistons?
__________________
bruno8747 is offline   Reply With Quote
Old 04-13-2011, 05:29 PM   #4
toycar
CB7tuner Member
toycar is very helpful toycar is very helpful toycar is very helpful
Way too much turbo for stock pistons
toycar is offline   Reply With Quote
Old 04-13-2011, 11:04 PM   #5
DKRM
CB7tuner Member
Quote:
They can be had for super cheap, that may be the reason. but it will defiantly be a smart idea to run forged internals, that way you wont be worried every time you drive if your internals will shit the bed today
Old 04-14-2011, 04:21 PM   #6
19dabeast85
CB7tuner Member
19dabeast85 is cool... so far.
You do not want to turbo an engine running a performance N/A cam, overlap will kill your boost among many other things, you need a turbo cam.
__________________
My Member's Ride Thread
19dabeast85 is offline   Reply With Quote
Old 04-15-2011, 06:54 PM   #7
project93
CB7tuner Member
well id either be running the 1.2 cam then or the 2.4 im aiming for above 300hp and 300tq i pretty much want to run 11's so if theres anything you see let me know i decided to scrap stock pistons im pretty m uch gonna run either bisi or something else pistons and bullet proof the block gonna be a big build so help would be appreciated
__________________
Old 04-15-2011, 10:13 PM   #8
wed3k
Contributing Member
wed3k seems to have made some friends! wed3k seems to have made some friends!
Send a message via AIM to wed3k
any forged piston will handle 300hp. race eng has cheap wiseco's and id send them out for a ceramic coating.
__________________
I <3 G60.
wed3k is offline   Reply With Quote
Old 04-17-2011, 04:31 PM   #9
dbsharp
CB7tuner Member
dbsharp is cool... so far.
hx35 is fine on a stock motor. Just dont go overboard with boost levels.
__________________
spin city
dbsharp is offline   Reply With Quote
