My question is are Evolution flywheels pre-balanced? The reason I ask is I purchased one from a very reputable shop and it very clearly has a heavy side. I can see this by mounting it on a spindle, spinning it and the same part will always face down. It will even roll backwards to get that spot down. I asked them if it was normal and they said DO NOT BALANCE THE FLYWHEEL!!!, but did not explain why its heavy sided. I find it odd to be that way unless it supposed to have a heavy side for some reason. I just put together this engine and I really dont want everything trashed so any input will be greatly appreciated.
Evolution flywheels
I'm quite sure that our engines are internally balanced. Still, it does seem odd that the flywheel would have a heavy side.
And yeah, Bisimoto wouldn't sell a cheapie brand, that I know for sure (that was what I meant by never hearing of it before... I figured it may be a low-quality brand.)
Although, I don't believe our oddly shaped pressure plates are all that balanced either. Perhaps we really don't need perfect balance.
I guess maybe I should just try them again and ask them to be a lil more specific as to why to not balance it. About the pressure plate though, even with it bolted on its still heavy in the same spot. I really hope this thing isn't cheap quality b/c I paid a lot more than I could have gotten a cheapy for. Ill try them again and post the response. Thanks for the help anyways
I had a Bisimoto 8.9lbs flywheel I ordered through him. Evolution was stamped on the flywheel and all the packaging said Evolution as well.
Honestly though, if you got it through Bisimoto and it feels off, give him a ring and ask.3 CB's gone....
1 WK Overland....
Still miss the CB though......maybe one day.
This is the exact one I purchased here. I sent them another email and am waiting reply. http://bisimoto.com/store/index.php?...roducts_id=142
Originally posted by ravenexi View PostMy question is are Evolution flywheels pre-balanced? The reason I ask is I purchased one from a very reputable shop and it very clearly has a heavy side. I can see this by mounting it on a spindle, spinning it and the same part will always face down. It will even roll backwards to get that spot down. I asked them if it was normal and they said DO NOT BALANCE THE FLYWHEEL!!!, but did not explain why its heavy sided. I find it odd to be that way unless it supposed to have a heavy side for some reason. I just put together this engine and I really dont want everything trashed so any input will be greatly appreciated.
