Old 05-08-2018, 02:49 PM   #1
boulky12
boulky12 is cool... so far.
New CB Owner, Power locks question
Whats up guys. I'm from Dallas, TX. Just got my CB7 about 2 months. It is my first Honda. I'm more of a classic chevy truck guy but it was cheap ($300) and i wanted to start saving some gas. I've been putting some work into her. Full tune up, replacing missing interior pieces, alarm, replaced all speakers, sub, put some wheels on her. She's been a good daily and I'm almost done with all the little things it needed since I bought it.
The problem I need help with is my Power locks. For some reason, they work when i flip the switch down (Lock). But if I flip the switch up (Unlock), nothing, not even a click. Same for both doors. Even with the key fob from my alarm, only lock works, unlock does not. I removed the power door lock unit (from the drivers door), took it apart, inspected it. All the soldering points look good. Nothing Looked burned.
What do you guys think?
Here she is: 1993 Coupe EX Auto 160,000 miles
boulky12 is offline   Reply With Quote
Old 05-08-2018, 10:31 PM   #2
fleetw00d
Check continuity of the yellow/red wire at the power lock control unit (in the door) to each of the door actuators. Check continuity of the black wire at the control unit to the G501 ground (under the carpet on the left side of the driver foot well).
90 LX 4dr 5 spd 376,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
07 Element EX AWD 175,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
Old 05-08-2018, 11:15 PM   #3
boulky12
I'll post the results as soon as I get a chance. Thanks
Old 05-11-2018, 07:51 PM   #4
boulky12
Sorry I took so long but I got some results and hope you can still help me. So I did have continuity from the power lock control unit to the driver door actuator. I didn't check the passenger door because I didn't feel like taking the door panel off. And I did have continuity from the black wire to the G501 ground.
Any ideas?
I'm thinking it could actually be the control unit, although it looked completely fine when I took it apart..
Old 05-11-2018, 08:23 PM   #5
Rilas
I've had to replace the lock unit on 2 different Accords now. They lost some functionality either locking or unlocking. A junkyard unit fixed it both times.
Old 05-11-2018, 09:10 PM   #6
F22Chris
x2 on a junkyard replacement. Honda made excellent quality lock actuators if you consider how long it took for yours to poop out. Dirt, moisture, and age will ruin anything over time. It is also entirely possible that the switch contact is worn down too. You can probably find both at a yard for $20.
You need to check ground at the passenger side too. Both doors should share the same G501 location.
Old 05-12-2018, 03:16 PM   #7
Size9zombie
Size9zombie is cool... so far.
Lock control units are very common to go bad on the 90 to 97 accords. They do not make new ones any more, from Honda or aftermarket companies.
Size9zombie is offline   Reply With Quote
Old 05-14-2018, 08:18 AM   #8
boulky12
Thanks guys for all the info. If I I get another Power lock control unit from the junkyard, could it be from a 4 door also? Or only coupe will work?
Old 05-14-2018, 03:23 PM   #9
F22Chris
Coupe only for the switch. Actuators might be the same..
Old 05-15-2018, 08:21 PM   #10
boulky12
So I went to the junkyard yesterday and got another Power lock control unit and it seems to have fixed the issue and the switches for Unlock/Lock are working on both doors.
The only thing that is not working is my doors will not unlock from my keyfob from my alarm. But they will lock. I'll double check the wiring but why else wouldn't they be able to unlock by my keyfob?
Old 05-16-2018, 02:37 AM   #11
ridin_low07
ridin_low07 is cool... so far.
There is always the possibility that the alarm lost memory somehow. I know it seems far fetched but it is a possibility.
ridin_low07 is offline   Reply With Quote
Old 05-16-2018, 08:45 AM   #12
boulky12
How do I make it re-learn?
