WHat rotors other than the acura cl 2.3 can i use for the Rotor over hub mod?
    I want to do the ROH mod since 3 of my wheel studs need to be swapped out and lower ball joins need to be replaced but i cant find any acura cl 2.3 hubs. All I find are the bearings I need the hubs. Please if anyone knows any other hubs that are compatible please let me know.
    Thank you in advance.
    http://www.cb7tuner.com/vbb/showthread.php?t=177927 <MY BUILD PROGReSS
    it won't be because cb7tuner told him to! It'll be because it's time to feed the trouser snake...
    There are no other hubs that are compatible
    But the parts brand new if you have to
    Also acura 2.3 and 3.0CL hubs and bearings are the same. The 3.0 just has bigger brakes.
      Literrally the only ones I've found are for a 1997 CL 2.2 for about 75$ a piece with bearings. would those work?
        I bought my hubs from Bernardi Acura of Boston via the internet. I think i paid like 97 bucks per hub over a year or two ago.
          I know this might be a stupid question but do the rear hubs work from the aacura cl 2.3-3.0
            No do not use the 97 acura CL hub parts
            The 1997 acura CL ( both 2.2 and 3.0 ) are still HOR
            You want 1998 to 1999 acura 2.3 / 3.0 CL hub / bearing parts
              It was never specified in the threads i read about if you can use the rear hubs from the 98-99 cl or not is this possible?
                I think the cl uses a bigger spindle so the rear hub wouldn't work. Why are you wanting to know about the rears?
                  Why do you want to use CL rear hubs?
                  The rear end of the accord is not HOR only the front is
                  Just use accord parts
                  I'd imagine they would work though because everything else is similar but im not 100% sure
                    Sorry i didnt elaborate on it but is it possible to use the cl rear hubs as the front accord hubs? I know it might be a dumb question but its worth a shot i cant find the front hubs anywere but the rear ones come out everytime.
                      No.... they're a totally different design. The rear hubs only work for the rear of the car. They have the bearing already inserter and slide over a spindle as opposed to the fronts which slide into the bearing and have splines to hold the axle. Try a jy and see if they have them. I know the pick a part here in Houston has a cl with what you'd need. One up there might as well.
                        Dang I figured they wouldnt fit thank though i greately appreciate it.But seriously look online and you cant find these front hubs anywere at all I called the dealer and they are 135 a piece for the front hubs only so 270 for just the hubs ! plus taxes.. lol nop I know there is a cheaper way if not ill go to the junkyard and pray i find one.
                          Yep
                          just stick to the CL front hubs and you're golden.
                            can you use the brakes off the CL? thanks
                              Yep
                              OK thanks for clearing that up man
                              Guess i just need to have patience.
