Turbo question F22A4
    Hey everyone, before you tell me to do a search, I tried and its not working for some reason. So I just have one quick question:
    If I am running all stock internals on a newly rebuilt engine (F22A4) that only has 1000kms, how much boost can i go with, without causing any internal damage?
    Most people tell me about 5-7 psi...is that correct or can I go more?
    Also, how much can i expect to pay for a turbo kit? and which one is the best?
    SORRY again for asking these common questions again, but Im getting an error messege everytime I try to search.
    Thank you!
    Well, I would wait to break the engine in some more (probably to about 3000kms) before doing anything with the car.
    Also, people say 8-10psi or whatever. That's misleading, it's not the amount of boost you run, it's the amount of power you make with that boost. Some people on here are making or have made around 350whp on 12 psi. Definitely out of stock F22A4 territory.
    It would also be cheaper to piece together your own kit. A popular one is the DSM setup (14B turbo, DSM manifold, DSM 440cc injectors, DSM BOV, etc).
    With the 14B, if you get a decent tune, you should be perfectly safe on 6-8 psi or about 200-230whp. However, DO NOT, I repeat, DO NOT hotrod the car if you haven't tuned it after the turbo install. It only takes a few seconds to destroy an untuned engine.
      what he said ^ and also for future reference, if the search doesn't work for some reason use google and just type what you want to search for followed by site:www.cb7tuner.com. That will probably work better than the forum's search function lol
        You need to keep the search simple... if you search for too detailed of a query, it'll give an error.
        By "search", most people don't mean to click on that useless button... they mean to dig through the forums to find info that applies to your question.
        I will eventually implement a Google search into the site. That will increase the effectiveness of the search button significantly.
        As for boosting a freshly rebuilt engine, 5-7psi with a properly sized turbo would be fine. You still need to tune it correctly, however. You could probably run up to 10psi with a good turbo and a good tune.
        I don't believe that there are any pre-made kits availible for us anymore. All the ones I've always known of seem to have vanished... our cars ARE getting old, afterall!
        You can build your own system for less money anyway... and by the time you have everything complete, you will have a very valuable understanding of how the system should work. NO Honda owner should ever install a turbo without fully understanding how and why things do what they do.
        Check out the cb7tuner.com bookstore here: www.cb7tuner.com/bookstore.htm
        I would recommend that you pick up Maximum Boost by Corky Bell, as well as Honda/Acura Engine Performance by Mike Kojima. Read those two books cover to cover, and you'll have a firm grasp on turbo (as well as a great starter knowledge on how to tune your car in general!)
          thank you all for the help! I will try using the google next time...
            Thanks for the heads up on the searching function. Never tought about using Google to search the site.
            Check out ESP engine mount kits for your CB7!!!
