Idk Whats Going On With My Car Help
    Ok.... so i have issues a bit back
    and i needed to replace the alt..
    so i did... i jumped it and it ran like a beast
    no problems went about 4 miles total, and had a total sputter. floored it makes popping sounds like its under a huge load, but it goes no where
    WTF is going on with it....
    i changed the spark plug wires they are fine
    My ground is also fine
    i have no dash activity
    gauges dont work
    please help
    thanks,
    Ty
    any oil in the spark plugs? when you remove the spark plug wires? That could be leaking tube seals underneath the rocker arms. I would check that first.
    member's ride thread
    91 Accord SE 176k
      im gunna run out and check that too.... anyother ideaS?>
        did you get the right alt. and did you replace the bat at the same time.
        Accord SE
        93se
        Members Ride
          Ok....
          no oil in plug cavity or on plug itself
          battery is braaaannd new...
          and the alt is from kragen (vehicle specific)
          did the alt check and everything
            Originally posted by 2.2lv8eater View Post
            Ok....
            ok... so, i had my buddy jump my car...
            it ran great... pulled the jumper cables off still ran ok... for all of 2-5 seconds...
            any ideas?
              either you got a bad alternator, or you forgot to plug something in.
              I forgot to plug in my alt one time after working on my car. drove on the battery for about 15 minutes before the gauges started going all wacky. then the car died and I immediately realized what I had done. (At this point I was stuck on the side of the freeway. had to hike to work and grab a jumper pack. lol)
                Did you put the belt on correctly? With the correct tension?
                1990 CB7 - Almost Done - Delta 272, SRI, 2.25 catback, Bisi intake manifold gasket, A6 intake double stacked, H22 plenum, AEM cam gear, F23a block, F22a head, Wiseco K20 pistons, DSM 450cc injectors
                2004 Z33 - Brembo BBK, Nismo spoiler, Nismo lip, Nismo shift knob, AEM CAI
                  is there a possibility for something simple on your problem like a plugged ass fuel filter? idk how it'd go on a honda but i had a caddy i did a $350 tune up to, then the prick chugged, backfired, idled good, then died... it was the only thing i didnt change... the fuel filter... i'd say check your fuel if you have good spark... sometimes simple things you overlook can be the biggest pain in the ass
                  THOU SHALT NOT SHIT IN DEEVE'S WHEATIES
                    or it's a bad alternator. I had to change it on my mx-3 4 times. Installed the first one, acted just like yours. Took it in for test, 1/2 volt output lol. Did that two more times then got smart and had the 4th one tested before I left the store. With that one installed everything worked perfect again. And that's the only trouble I've had with O'Reilly's. Good luck man, I hope it's nothing major.
                    Officially "hilarious mad sarcastic"! Thanks CB74christ for the recognition of my work.
                      Get a multimeter out and check the voltage over the battery poles with the engine off and then on and see what you get... you should probably have near 14v with the engine running, anything under 13 and I'd say you got a bad alternator.
                        here is how to check if your alternator is working properly:
                        1. Start your car
                        2. Unplug the battery
                        3. The alternator should be able to handle the power loads of the entire car. The battery of any car is mainly to start it; after wards the alternator takes over.
                        Make sure the current output of the alternator is properly spec'd; if anything, make sure the current output is higher than needed; that way you can run a nice amplifier to your speakers.
                        good luck
                        DEVOTE
                        FS: Lokuputha's Stuff
                          1. Start your car
                          good luck
                          Watch out plugging the battery back in dont do it while the car is running could send a voltage spike to the computer and fry it.
                          -Will
                            1. Start your car
                            good luck
                            THat is also a potentially great way to cook your new alternator and possibly your wiring harness too.
                            The alternator NEEDS the battery as a voltage reference as to how much charge it is required to deliver.
                              make sure the plug on the alt. is secured on the alt. when I removed my Alt during my headgasket rebuild, the little plastic connector thing broke so I had to zip tie it to make it stay on the alt. Otherwise it would wiggle itself loose.
                              91 Accord SE 176k
