Hey all, long time no see. I'll try and keep this as short but informative as possible. I have a 1997 accord ex with a built bottom end F22B1 on 10 psi. Recently I've had an issue where any time I make boost, I go full rich and the car sputters and makes no power. The only thing I changed leading up to this was a bigger intercooler. That being said the car ran great for about 20 miles after the install and then all of a sudden started having issues. I've checked every sensor, swapped map sensors, tightened all clamps, checked all vacuum lines, checked spark plugs for fouling, checked for any leaks or weird noises, check fuel pressure, and that's all I've done so far. The car will start right up and run fine out of boost. As soon as I get to 1 psi I peg full rich and like I said the car barely runs. I don't know if it's an ignition issue and I'm suddenly not able to burn all of the fuel, or if its a fuel issue causing too much fuel to be injected. The only other recent thing I did was rebuilt the distributor about 3 months ago. No issues with that what so ever though. Any suggestions? Thank you!
Help with F22B1 suddenly too rich
Originally posted by F22Chris View Post
Are you running it with a tune? What are your o2 values when it happens?
Originally posted by deevergote View PostThanks for sharing the solution. Someone has already referenced this thread in an effort to help someone else with a problem that sounds similar!
