So I picked up another 1992 accord that has been sitting for about a year and a half or two years. I looked at the oil, its dark and nasty, going to drain and flush. Coolant seems fine, just needs a top off. But I do not know about the gas. Does it need to be replaced or can I just power through it? Also is there anything else I should check before trying to fire it up for the first time?
Getting a Car running after two years
Originally posted by Rat View PostSo I picked up another 1992 accord that has been sitting for about a year and a half or two years. I looked at the oil, its dark and nasty, going to drain and flush. Coolant seems fine, just needs a top off. But I do not know about the gas. Does it need to be replaced or can I just power through it? Also is there anything else I should check before trying to fire it up for the first time?
I would absolutely drain what fuel you have in the tank before trying to run it. the fuel is most definitely bad. At the same time try and flush what may be left in the lines as well. Take in consideration your injectors may be gummed up as well.
So do NOT power through it, take the extra time to properly clean your fuel system.
As a precaution, I'd flush the coolant as well. Just because it "Looks" good and may only need to be topped off I'd suggest doing a coolant flush as well.
Ethanol gasoline has a shelf life of about 2 years. Back in the day when gas had lead, it had a MUCH longer shelf life. Drain and replace all fluids, along with high wear ignition components. So - plugs, wires, cap & rotor. Do multiple oil changes, and a valve adjustment along with a valve cover gasket and rocker o-rings.
Coolant that isn't a newer long life type should be changed every two years. Long life coolant should be changed every five years. Get the newer style coolant from Honda when you refill.
Another thing to look into is the timing belt/water pump. All neglected basic maintenance items is what I'm getting at here..
