I picked up a 1993 accord 2.2, for my daughter last week and the idle was around 100-200rpm ,,,,I have cleaned and adjusted the IACV, FITV and TB (replaced the gasket as well),the EGR plugs are new and seem to have been removed and replaced, I assume that the ports were cleaned. I also have checked for vacuum leaks w/carb cleaner over every vac source including the intake. Topped off and burped the cooling system, unplugged the IACV while running and the idle drops but surges quickly only rising 100-200 rpm.
Still have the surging idle after cleaning TB, IACV, FIV, EGR ports and the EGR, someone said to pinch off the TB vac line and see if it dies, I pinched off the TB vac line and it did die. Is that important? I decided to order another IACV (off eBay, cheap) and it should be here in a couple of days, I hope it works. I cant find any vac leaks, sprayed C Cleaner everywhere with no change. Checked ABV and is good, it dies when I pinch off the vac line on the TB, I am still waiting to find out if that means anything.
