Nor*Cal what did you do to your car recently?
This is a sticky topic.
    New oem side skirts installed.
      Shaved off the side emblems
      '04 SB AP2 211whp 150wtq
        Another ballast went out again. Hopefully exchanging the ballast and wire harness asap..DDM Tuning sucks bawlz.
          Umnitza > Everything
          Cali.Dumps.Harder.
            my bud got a set of those like 7 years back and they still work fantastic.
            I <3 G60.
              got my car back shop didnt do shit.
              Found the problem to my swap. running obd2 injectors instead of obd1 ones.
              Installed a new Blox TPS. and got a new engine harness. a honda in ATL had one laying around and let it go for dirt cheap.
              just need to bolt up my front end and ill be good to go
                Installed new pads but couldn't get the rotors off... I EVEN BROKE THE BREAKER BAR THAT I GOT FROM AUTOZONE!!!! (the nut screw was installed wrong before, not by me)... And i did a tune up... Spark plugs, wires, air filter, oil and filter, its running strong now!
                  you mean high impredence vs low impedence injectors?
                  I <3 G60.
                    Yep pretty much.
                      i fixed the badass exhaust leak. YAYA!!
                      Turbo F22 Under Construction
                        changed my exhaust went from megan type 2 to the megan m-dt
                        from this
                        [IMG][/IMG]
                        [IMG][/IMG]
                        to this
                          Do you still have the old one by chance?
                          1996 Honda Civic LX 2009-2012
                          2012 Kia Optima LX 2012-2013
                            I <3 G60.
                              Did the spark plug seals and valve adjustment. I also installed my white TypeG valve cover.
                              2013 Honda Fit Sport Alabaster Silver Metallic GE8
                              2013 Accord Sport Modern Steel Metallic CR2
                              CB9 http://www.cb7tuner.com/vbb/showthre...hlight=hostile
                              CR2 http://www.cb7tuner.com/vbb/showthread.php?t=197787
                              GE8 http://www.cb7tuner.com/vbb/showthread.php?t=199289
                                duuuuuude I hear ya. Their customer service sucks money bong balls to.
                                I had good luck with www.retrosolutionsllc.com. I used their night visions, all the way up to the digitals. I had one failure and they sent me one within 2 days. I didnt even have to send back the old one. Very good quality.
                                Also morimoto ballasts I hear are very good as well.
                                DDM is going down though, they may not carry hid for much longer.
                                Retro!
                                Hater
