Took battery out and now it won't start.
    Hello everyone I been a member for a few months. Using info here before I bought my cb7 . Well yesterday after I put my battery back on my car isn't cranking. It's as if my alternator died but my hazards still work. no power anywhere except the hazards and horn. Ill be honest the battery was rigged. The previous owner placed screws on the posts to fit the terminals. Me being a dummy dropped one of the screws into the car, now it won't start without it . Changed terminals and still only hazards and horn , brake lights work . No interior lights of any kind . Sorry for the grammar errors.
    So it worked before battery was pulled. Now it doesn’t? Was the battery on a charger while off the car? Was it off the floor when not in use? First thing I would do is get a new battery especially if the old one was rigged.
    ~Nick~
      If you have no power anywhere, it's more than likely the battery. Have you tried charging it? You could have it load tested at a local parts store.
      The alternator does not supply cranking/starting power to your starter or ignition. The alternator only charges the battery and runs the electrical once the engine is running.
      MR Thread
      GhostAccord 2.4L Blog
      by Chappy, on Flickr
        Power only to the hazards , brake lights , horn. When the key is in the ignition there are no dash lights or the beeping noise it normally makes.
          Battery is good , tested it at AutoZone . I just disconnected and reconnected the battery , new terminals and still same problem. Could it be a fuse ?
            Check your fuses and all the ground and power connections to and from the battery. Check to see that when you pulled the wires/connections off the battery that you didn't inadvertently disconnect a battery ground or power wire.
            MR Thread
              Turns out it was a fuse , big black fuse.
