Old 09-05-2017, 06:46 PM   #1
zZcommandoZz
zZcommandoZz is cool... so far.
Rebuilt motor and just set timing belt but will not start anymore
Hi i just rebuilt my F22a1 and was running before rebuild i stet the timing belt and lined up all timing marks but will not start i can smell gas after i try and start it. im lost on what to do now?
https://flic.kr/p/ELMAhy
zZcommandoZz is offline   Reply With Quote
Old 09-05-2017, 07:13 PM   #2
sonikaccord
Trace your steps back, triple check timing naturally.
How's your spark?
<Click for story - Welcome back!
Old 09-05-2017, 07:34 PM   #3
Jon
Jon is very helpful Jon is very helpful
Are you sure you're not 180° off?
And yes, how is your spark?
Could post a list of EVERYTHING you can check and see, but the best thing to do would be to go back through all your steps and make sure you didn't forget to reconnect something simple.
Jon is offline   Reply With Quote
Old 09-05-2017, 08:22 PM   #4
zZcommandoZz
Timing
yeah checked that looks all good still how can i check for spark?
Old 09-05-2017, 08:34 PM   #5
Jon
Pull the plug and plug wire out of the cylinder head, ground it to the frame/engine, and give it a crank and look for spark. While doing this, don't be leaning on the car...
Picture added for clarity of how to ground the plug.
Old 09-05-2017, 08:55 PM   #6
zZcommandoZz
lol ill make sure i dont
Old 09-05-2017, 10:27 PM   #7
zZcommandoZz
https://streamable.com/8t1fn i have spark ?????
Old 09-05-2017, 10:46 PM   #8
Jon
Hard to tell (my fault because I'm on my stupid Lenovo Yogabook thing), but it looks like you have spark. Looks faint on my end thiugh (yellowish), but again hard to tell.
Check battery voltage? Both as it sits and while you crank it?
Old 09-05-2017, 10:49 PM   #9
zZcommandoZz
ok and yes its yellowish
Old 09-06-2017, 06:16 PM   #10
sonikaccord
Your motor sounds like it's spinning really freely. Do you have a compression tester?
Old 09-06-2017, 06:51 PM   #11
Bunta
Bunta is cool... so far.
You mentioned smelling gas, was that with a plug pulled or with everything sealed up? I wouldn't want to create open sparks if you have some sort of a fuel leak.
Old 09-06-2017, 09:00 PM   #12
zZcommandoZz
Gas smell
that was with the plug pulled
Old 09-06-2017, 09:01 PM   #13
zZcommandoZz
yes i do have one
Old 09-15-2017, 09:16 PM   #14
zZcommandoZz
so i tested all 4 cylinders and no compression
Old 09-15-2017, 09:45 PM   #15
Jon
No compression or really low compression?
When no compression is mentioned, first thing to mind is a blown or bad head gasket.
And are you sure your timing isn't off? It may be off enough that on the compression stroke the valves aren't closed, thus no pressure is built = no compression.
Old 09-16-2017, 02:52 AM   #16
zZcommandoZz
ill double check timing tomorrow and make a vid for you guys and head gasket should be good changed that while i was rebuilding the motor
Old 09-16-2017, 06:24 PM   #17
92smokeaccord
92smokeaccord seems to have made some friends! 92smokeaccord seems to have made some friends!
if there is little to compression put a cap full of oil down each cylinder to semi seal the rings.some rings do not seal correctly till they get hot or you made all the rings line up in a line...
my new turbo build
92smokeaccord is offline   Reply With Quote
Old 09-19-2017, 01:28 PM   #18
zZcommandoZz
welp still lost
https://www.youtube.com/watch?v=oC6J6empcJg
Old 09-19-2017, 02:29 PM   #19
Jon
That is an odd tone when you switch from accessory to ON.
Do you hear the main relay switch on/prime the injectors (I can't tell from the video)?
Have you checked your thermostat housing ground?
Old 09-19-2017, 04:43 PM   #20
sonikaccord
Yep, zero compression. Your timing is most likely off. Can you get a pic or vid of your cam gear and crank(or flywheel, which ever one has the crank TDC mark)?
As far as that increase in tone, that usually happens when the voltage drops on a timer IC. If your fuel pump priming is making the batt voltage drop that much, then you need to check your battery as well as your grounds.
Edit: A few other things I noticed, all of your door indicators came on and it looks like your cluster dimmed a little. Your radio restarted when going from ACC to ON. What happens if you turn your lights, rear defrost, fan on high? Or just throw a multimeter on your battery.
