Old 10-08-2017, 04:13 PM   #1
Tuage
Tuage is cool... so far.
Whinning noise from engine bay driver side
Hey guys I've got an accord 92 ex...there is a whirring whine noise coming from driver side near pulley and belts...I'm running with no ps pump belt and my alternator was replaced and has less than 1000 miles on (re manufactured) I'm leaning toward maybe bearings in alternator but wanted to know if there would be something else to check firs being that the alternator is technicality new...
Note; the sound is more of an irritant than a problem as it doesn't affect performance, and it's most noticeable at idle.
Thanks in advance
Tuage is offline   Reply With Quote
Old 10-08-2017, 04:19 PM   #2
LadyG
Golden
LadyG has a HUGE cock! LadyG has a HUGE cock! LadyG has a HUGE cock! LadyG has a HUGE cock! LadyG has a HUGE cock!
Do you have ac?
LadyG is offline   Reply With Quote
Old 10-08-2017, 04:31 PM   #3
F22Chris
F22Chris seems to have made some friends! F22Chris seems to have made some friends!
Tight belts whine. Take off the accessory belt and see if it stops.
Old 10-08-2017, 08:33 PM   #4
Tuage
Yea I do have the ac connected but don't usually run it...what is the tension spec for the accessory belt? If I push on it from center between alternator and balancer it goes in about 1/2-3/4 inch
Old 10-08-2017, 09:17 PM   #5
Tuage
Old 10-08-2017, 10:39 PM   #6
F22Chris
You can also use a stethoscope or long screw driver to pinpoint the noise.
