ok so I had a previous problem cluster turned on randomly nd when I steped on the brake. I found out under the dash a cupple wires burnt. I wrote down what wires go where. I cut them nd rewired them. now every now and then when my lights(cluster) is on it randomly blinks. any1 have a idea why this is happening 2 me. I checked the fuses some dumbass put a 30A fuse for the blinkers when it's suppose to be 10. I put the 10 in it's not blinking the the beat of the music just randomly.
cluster blinks slow
cluster blinks slow
http://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
diy whore riiittteeee here
[URL="http://www.cb7tuner.com/vbb/showthread.php?p=2208455"]
http://www.b20vtec.com/forums/members/pr3pg4lyfe.html
where is that located?? I have some type of relay in my hand. it has 5 prongs but only 4 connectors connect to it. 2 are goldish color and the other 3 are coppered color. and the color of the relay is black is that it?? it's not connected it was jus hanging there by black tape. it's weird nd getting on my nerveshttp://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
The turn signal/hazard relay is by the driver's left foot. There's a little side wall panel on the left side under the dashboard - that's the fuse panel. The turn signal flasher is above the fuse panel farthest to the left above the big square box. The turn signal flasher is about 1-1/8" wide by 7/8"tall and 1-1/2" deep. It's hard to get out with all the other parts around it and you have to spread out the little side clips on each side of the flasher relay to release it. Make sure you have a light - it's hard to see under there even in the day time.
yea all my lights are working fine. there's no light out. I have the door open night lights on just the cluster blinking like a retart.http://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
nope not the flasher in my hand. there's only 5 wires going to this relay.http://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
dont know either. i no that the wires i had cut, when they were cut, the lights didnt go on. no hazards nuthing. once i put new wires in and connected them the way they were everything was back to normal. except the blinking slow and i didnt connect that relay still worked connected it to the relay nuthing changed??http://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
