Go Back   CB7Tuner Forums > Parts & Performance > Swaps
Old 06-17-2017, 10:33 PM   #61
mjsstanley
CB7tuner Member
mjsstanley is cool... so far.
Old engine out.. In the process of cleaning up the bay. Gonna remove as many unnecessary wires and parts possible. Making progress.
mjsstanley is offline   Reply With Quote
Old 07-06-2017, 03:58 PM   #62
mjsstanley
CB7tuner Member
So somehow all of my pics disappeared no biggie, half of the parts I started with were traded for something different anyway. So here is the list of what's here to stay and being put together currently.
Motor is at the machine shop getting cleaned, bored, resurfaced, etc. Aiming for this swap to be done by the end of next month.. Any longer and I'll be damn near $15k lol.
Looks like I have to find another way to post pictures other than photobucket. In the meantime, here is the confirmed list of parts I'm using. We'll save pics until the motor is actually in the bay.
CYLINDER HEAD
- K20Z1 PRB Head
- 4 Piston Racing RR4 Camshafts
- Skunk2 Ultra Street Intake Manifold (Ported & Polished)
- S90 76mm TB
- Ferrea 5000 Flat Faced Valves
- Supertech Valvespring & Titanium Retainers
- Adjustable Cam Gears
- K Tuned 4-2-1 K Swap Header
BLOCK
- K24A2 Acura TSX Block
- Arias Pistons 88mm 12.5:1 CR
- K1 Technologies Lightweight I Beam Rods
- PRB Type S Oil Pump
- ARP Rod Bolts
- ACL Race Bearings
TRANSMISSION
- K20Z3 SI Transmission Casing
- K20A2 Type S Transmission Internals
- K24Z3 OEM LSD
- XTD Stage 3 Clutch & Lightweight Flywheel
MISC
- Innovative CB K Swap Mounts 60A
- CX Racing 3" Triple Core Halfsized Radiator
- PRB ECU w/ KPro V4
- Yonaka RSX Type S Axles
- Trubendz 2.5" CB7 Exhaust Piping
- Vibrant Ultra Quiet Resonator & 2.5" Muffler
- RDX Fuel Injectors
Old 07-08-2017, 05:45 PM   #63
sonikaccord
Contributing Member
sonikaccord is cool... so far.
Hey, which machine shop are you using? I'm testing out Scott's in Fayetteville, but I don't know if I want to give them a block.
__________________
sonikaccord is offline   Reply With Quote
Old 07-08-2017, 10:31 PM   #64
mjsstanley
CB7tuner Member
I used Superior Parts & Machine on Moreland Ave. Good prices and great, quick service.
Old 07-09-2017, 08:43 PM   #65
'93CB7Ex
Gold Member
'93CB7Ex is cool... so far.
rsx axles work?
__________________
k24a2 in progress
'93CB7Ex is offline   Reply With Quote
Old 07-09-2017, 09:08 PM   #66
mjsstanley
CB7tuner Member
Haven't tried them yet but they should work by swapping the inners. Also heard that TSX axles with the Accord outers work.
Old 07-09-2017, 09:22 PM   #67
Jarrett
Contributing Member
Just go on RockAuto.com and check axle lengths and compare inner/outer designs and spline counts.
__________________
If you see any threads or posts of mine whose picture links are broken (there are a lot), please send me a link to the thread. I will gladly fix them. I don't see it as a fruitless burden. This site has helped give me quite a bit of my drive and passion for cars, and fixing my picture links is the least I can do to give back.
Old 07-09-2017, 09:45 PM   #68
'93CB7Ex
Gold Member
im using the prelude sh axles.
__________________
k24a2 in progress
Old 07-14-2017, 12:38 AM   #69
F22Chris
CB7tuner Member
F22Chris is cool... so far.
Quote:
There's also Dover by Summit, and Joes in Decatur. I've never heard of Superior.. might have to stop by there
__________________
F22Chris is offline   Reply With Quote
Old 07-19-2017, 11:11 PM   #70
mjsstanley
CB7tuner Member
Quote:
Yeah I reached out to Dover but they only do cylinder heads. Superior is really good and also Will's Machine Shop in Chamblee.
Old 07-22-2017, 03:42 PM   #71
mjsstanley
CB7tuner Member
Got motor back from machine shop, ended up going with Will's Machine and it turned out great! Now time to put everything together..
Red Powder Coated Valve Cover (came out much better than expected)
Cylinder head cleaned and resurfaced..
Block bored and honed to 88mm now..
Crank balanced and polished..
Old 07-22-2017, 06:47 PM   #72
sonikaccord
Contributing Member
Pics no work
__________________
Old 07-22-2017, 10:03 PM   #73
mjsstanley
CB7tuner Member
Sorry, try again. Been having a hard time posting pictures since photobucket switched to this 500 thing.
Old 07-25-2017, 12:49 PM   #74
mjsstanley
CB7tuner Member
Finally have some free time to get my pictures uploaded again. While the engine is being built, I'm gonna try and do a little paint work to the engine bay. Setting a timeline to have the car up and running by the end of August.
Mounts..
Valves..
Springs & Retainers..
Camshafts..
Throttle Body..
Intake Manifold..
Header..
Pistons..
Rods..
Transmission..
KPro..
Radiator..
Axles..
Exhaust Piping..
Engine bay..
Can't wait to have this thing on the highway!
Old 07-25-2017, 07:26 PM   #75
'93CB7Ex
Gold Member
the more i see that budget k swap header the more it looks like that will be the one to work.
__________________
k24a2 in progress
Old 07-25-2017, 07:45 PM   #76
mjsstanley
CB7tuner Member
That's what I'm thinking too. It's the only header that goes from 4 to 2 before the curve at the bottom. Unless you run the Skunk2 alpha that has all 4 cylinders coming down individually.
Old 08-26-2017, 11:02 AM   #77
mjsstanley
CB7tuner Member
Car finally off to the shop.. Motor should be completed on Monday
Old 08-28-2017, 12:58 PM   #78
sonikaccord
Contributing Member
It's Monday!
Can't wait for vids.
__________________
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
