Old 07-11-2016, 03:04 PM   #1
Cb7beamer
Newcomer
Cb7beamer is cool... so far.
Transmission problems
Hey guys I was wondering if anyone knew what could be wrong or is going on I have a 93 accord 2 door with a f22 non vtec.the car won't go in neutral I can find 1st 2nd 3rd and 4th reverse. .any clues what this could be please help.
Cb7beamer is offline   Reply With Quote
Old 07-11-2016, 03:33 PM   #2
lbus9168
Contributing Member
lbus9168 may have said something they shouldn't have...
You should probably specify whether it's automatic or manual.
__________________
sold! But here's my build thread for those interested.
http://www.cb7tuner.com/vbb/showthread.php?t=206864
lbus9168 is offline   Reply With Quote
Old 07-11-2016, 08:40 PM   #3
Cb7beamer
Newcomer
Yea sorry about that it is 5 speed manual
Old 07-11-2016, 08:49 PM   #4
Grumpys93
Contributing Member
Ive never heard of it not going in neutral. If you can transfer from gear to gear then you are moving through neutral. Not to question our driving ability but you do know when your in neutral correct? If the shifter can be sweep fully from the driver side to the passenger side. Should be able to jiggle it and the engine wont bog down when you let of the clutch.
__________________
~Nick~
Old 07-11-2016, 08:59 PM   #5
lbus9168
Contributing Member
You go into neutral to get into each gear. If you're saying you can't get the car out of gear when its on then your clutch is gone, but honestly I'm confused to what you're even saying.
__________________
Old 07-12-2016, 10:54 AM   #6
thumping_accord
CB7tuner Member
thumping_accord is cool... so far.
Quote:
Even if the clutch was gone he should be able to pull the trans out of gear, he just wouldn't be able to put it in gear.
OP, when you say your changing gears is the car running or is it off?? Can you give us a little bit more detail on whats going on? I too find your question/problem confusing.
__________________
If at first you don't suceed, then skydiving is not for you.
I try not to down talk anyone, when I read my old questions I realize I was an idiot too.
thumping_accord is offline   Reply With Quote
Old 07-12-2016, 02:11 PM   #7
lbus9168
Contributing Member
Yeah, I know, I'm just trying to make a really wild guess.
__________________
