Accrdwgnguy : 1992 Accord LX
    Originally posted by H22WAGON93 View Post
    u should come this weekend and get the engine. me and Dan are gonna do a valve cover gasket and cam seal on my wagon
    This weekend sounds good, I have a engine hoist just chillen in the back of my truck.
    1992 Accord Wagon (RETIRED)
      I totally forgot to post on your mr thread!
      wagon is still clean! You still looking for tan leather inserts lol
        I wish man, I may be doing an engine swap in the near future and I decided to pay for school out of pocket lol.
        Thanks for the comments tho, at least the car is still looking good!
          I like that 2.2i badge! Looks good! I've been looking for one but no luck! How can I find it? What does the i stand for?
          1990 Accord EX
            You can find them on ebay sometimes or, where I got it, in the classifieds here. Just keep looking!
            The "i" stands for fuel Injected, it was the trim for the top model in Europe. The lower models were carb'd
              How much was it? Our cb's are fuel Injected right? I don't want a badge that says something I dont have! Lol
              1990 Accord EX
                LOL yup all USDM CB's are FI
                  I have a quick question for you... If you could PM me cause I dont check too often
                  1st - Where did you get the arm rest and what did it come out of?
                  2nd - The ebrake cover looks dif. than my 91, did they change in 92 or is that from a dif. model too?
                  Thanks in advance buddy and nice wagon
                    Disaster averted!
                    I took everything apart today, the front balance shaft sprocket loosened up and fell off(opps) destroyed my Genuine Honda balance belt and messed up the timing belt as well. The cam was also 90 degrees off. So I lined everything up, put a new timing belt on and it started up! Ran a little rough tho, so I did a compression test. My results :
                    Cyl #1 - 180 LBS
                    Cyl #Two - 185 Lbs
                    Cyl #3 - 175 Lbs
                    Cyl #4 - 170 Lbs
                    So all seems well, I'm gonna put more stuff together, and run it to temp for a 1/2 hr or so. If it smooths out and runs ok, I'm gonna throw in the Bullfrog cam
                      Ok did a slight mod, "rear fogs"
                      Off:
                      On:
                      I used a relay and made adapter harnesses from a junkyard car. The inner tails still function as stoplights when its switched off. It works good and the cost to me was zero, as I had all the wire and relay kicking around. What do you guys think?
                      Nice work
                      My ride History:
                      Accord 90 lx auto: Gone
                      Accord 91 dx MT: Gone
                      Accord 92 lx auto: Gone
                      1st to D.I.Y custom RED/CLEAR's
                        Originally posted by CB7_91/DX View Post
                        Nice work
                        Thanks bro, I have fun with wiring.
                          Cool, are they 2.2?
                          1990 Accord EX
                            To swap or not? That is the question.
                            So since the timing belt incident I no longer trust the F22 that sits in my wagon. Sure it starts and runs and has great compression, it makes some noise. I haven't put any work into it since then, I was planning to take it off the road for this winter because the rust is eating the car (and me). So I have spent my time since then getting my Civic beater swapped and roadworthy.
                            My thoughts and dreams have been so far:
                            #1 - Rebuild the F22 into some sort of monster. I have in my possession a Bullfrog/Gude F22 cam, which is roughly equivalent to a Bisi stg 2. I have the H23 IM and DC sports header installed on the car. I have a spare F22A1 with great compression that was given to me by a good friend. Plus a P06 I chipped for this setup. This would be a fun project as I have never toyed with Honda internals.
                            #2 - H22A swap. This would be a good choice as well, if I wanted to make this car a summer DD. This car is my baby, after all, but I have another hot rod project (the Malibu) that I haven't touched in a while. I have driven a couple of H22 Accords, one a tuned wagon, and its quite fun. I wouldn't do any other mods to the engine besides a tune, a 200hp DD would get me in enough trouble, although the wagon has a much lower profile than say, a 06 Civic Si.
                            #3 - Be the first K24 Wagon in the universe! This would be a unique, yet costly swap, but the potential is amazing with these engines. Plus six speed stick is something I've always dreamed of having in the wagon. TSX swap + supercharger=awesome.
                            All these options are depending on money, of course. School isn't exactly sucking me dry, though I did just drop enough for a H swap to cover the first semester. I plan on doing something about it over the winter and into the spring. Undecided on what to do, so far.
                            Whats your opinion?
                              3.0L VTEC bro.
                              wat?
                                Whats your opinion?
                                K24 FTW!
                                1990 Accord EX
