I'm I've created a new thread to document everything.
Start-Up Video. Page 13.
A little background on the situation. I bought my CB two years ago, and began building it into a vision I had some years back. The car was taken care of, but had small engine problems. I got tired of nickle and dimeing, and decided to let the motor die on it's own. The timing belt finally snapped on 11/26/2012, and it just so perfectly happened around the corner from my residence. How convenient? It's currently sitting through the winter awaiting a new heart transplant.
As of this moment, I'm hunting down parts and prices getting ready to order the rest of the stuff needed for the swap. I plan on fully building it in the near future, but for now, this thread will only contain the swap information.
PARTS LIST:
Additional replacement parts while the F22 is out of the car.
I will be using OBDI injectors and distributor. I'm not sure which ECU I'll be using yet, but I'm thinking a chipped P28.
APPARATUS:
SWAP PHOTOS
PARTS LIST:
- '94 JDM H22A. ...Installed...
- JDM M2B4. ...On Hold...
- JDM TD60 Distributor. ...Installed...
- JDM P13 ECU. ...Installed...
- Genuine HONDA water pump. ...Installed...
- Genuine HONDA timing belt. ...Installed...
- Genuine HONDA balance shaft belt. ...Installed...
- Genuine HONDA valve cover gasket set. ...Installed...
- Genuine HONDA throw out bearing. ...On Hold...
- Rear & front main seals. ...Installed...
- Accessory belts (alternator - AC compressor, PS). ...Installed...
- Kaizen Speed manual tensioner. ...Installed...
- Tune up items (spark plugs, wires, etc.). ...Installed...
- Prelude high pressure line. ...Installed...
- 4 new motor mounts. ...Installeded...
- Prothane or Energy Suspension front mount insert. ...On Hold...
- Header and down-pipe. ...Installed, but needs modification...
- Exedy Stage I clutch. ...On Hold...
- Fidanza Lightweight Flywheel. ...On Hold...
- Omni 68mm throttle body. ...Installed...
- AEM short ram inatke. ...Installed...
- New brake master cylinder. ...Installed..
- New clutch master cylinder. ...On Hold...
- '90-'93 Non-ABS front hard brake lines. ...Installed...Ran new lines...
- Integra 40/40 Proportioning Valve. ...Installed...
APPARATUS:
- Engine Stand
- Engine Hoist A.K.A. Cherry Picker
- Metric Sockets
- Metric Wrenches
- Wire Cutters/Strippers
- Screw Drivers
SWAP PHOTOS
