Old 02-07-2009, 12:12 PM   #21
90JDMACCORDEX
90JDMACCORDEX is cool... so far.
im thinking its the ignition switch because the car started fine and then all of a sudden when i went to drive it i went 3 miles and it drove fine then all of a sudden it shut off and wouldnt start back up
90JDMACCORDEX is offline   Reply With Quote
Old 05-17-2009, 09:16 PM   #22
Anniversary-Ed.
Anniversary-Ed. is cool... so far.
Send a message via AIM to Anniversary-Ed.
Originally Posted by JunyAccord View Post
My distributor was leaking when it my car used to stall. I replaced that along with the Idle air control valve. Ran fine for a little while.
Recently i noticed bogging, and when i pulled my spark plug wires off there was oil in the tubes. So now i have to change the valve cover gasket, upper and lower rings, and the spark plugs. Check all those i mentioned.
Ya... mine was the distributor. i must have had a short in it cause it crapped out at totally random times. My mechanic had no idea what was wrong though.
Anniversary-Ed. is offline   Reply With Quote
need-help , problem , stall , stalling , trouble
