Vapor Lock Possibility?
    Hi there, I have a 92 honda accord and i'm noticing a pattern on why my car isn't starting. During hot days i can't seem to fully start my car, it cranks but it is still a no go, then when i try it during a cooler temp. or at night it starts perfectly fine and doesn't even hesitate and after i start it, it seems to be normal as it starts again after i travel somewhere and come back home. I'm new to cars and not very familiar with terms and car parts but i've been reading on problems like mine and i'm wondering if it's possible that it can be a vapor lock causing the problem as everything else works fine under the hood. Is this the cause of it? If not, feel free to leave me insightful comments on what other possibilities it could be and how to solve it.
    Vapor lock is almost unheard of on FI engines, unless there's problem with the system. You should check on main relay. There are many threads on here as well as on internet talking about "how to" re-solder it as a fix.
    A&P-IA
      Sounds like a main relay to me also. They are located under the dash above all of the pedals. It's a small gray box. Parts stores sell them for around $40-$50 or you could just go to the junkyard and get a couple of them and try them out.
      Resoldering the points on the one you have would also be an option. The cracks will be very small and you may have a difficult time seeing them. Just use a soldering iron to reheat all of the points on the board and add solder as needed.
        First, make sure you go through all the testing procedures outlined in the service manual before purchasing anything. A multimeter is your friend.
        I personally had the same issue but it turned out to be that the wiring harness to the fuel pump relay had a bad ground (open circuit). The fuel pump would not turn on making it look like the relay was the culprit. As a temporary fix I spliced into the relay connector on the harness straight to ground and it allowed me to get the car home to fix it correctly.
        ENG: MAIN RELAY REMOVAL AND REPAIR (pics)
        http://www.cb7tuner.com/vbb/showthre...ght=main+relay
        Honda No Start? POSSIBLE Main Relay
